abinidi
Help With Php/mysql Display Issue
I'm trying to get MySQL to return a SUM of items in one of the columns in my database table, and convert that into a format that I can display in PHP.
Here is the code I'm using on my .php page:
>$queryDinnerNumber="SELECT SUM(dinner_number) FROM data WHERE dinner = 'yes'";
This works, because when I run the code on the SQL tab of PHPMYADMIN, I get a table that has one row and one column, with the resulting value in that cell.
However, how do I display that value on my webpage?
Here is the code I'm trying:
$resultDinnerNumber=mysql_query($queryDinnerNumber);
echo $resultDinnerNumber; ?> people have been invited to the dinner.
However, on my page, I see the following:
Resource id #7 people have been invited to the dinner.
How do I convert the value from the results into something I can display on my web page?
Share this post
Link to post
what you have returned is a resource, not actual data
you need to do something like this:
>$queryDinnerNumber="SELECT SUM(dinner_number) as total FROM data WHERE dinner = 'yes'";
while($row = mysql_fetch_array($resultDinnerNumber))
$actual_results[] = $row;
print_r($actual_results); // this will print out your results array so you can see the values!
echo $actual_results[0]['total'] .'people have been invited to the dinner.';
Share this post
Link to post
Thank you. That was the piece I've been missing!!
Share this post
Link to post
