abinidi
Problems With Curl
I'm doing work on a client's site, and I recently upgraded the WordPress installation to WP 2.6; I also upgraded the e-commerce plugin to the latest version.
Now, I'm getting a CURL error when I try to use the checkout function in the store. You can reproduce the error on my TCH-hosted site: http://solutionsforpreparedness.com/store/ (add an item to the cart, then select "checkout".
The error message is:
Warning: curl_setopt() [function.curl-setopt]: CURLOPT_FOLLOWLOCATION cannot be activated when in safe_mode or an open_basedir is set in /home/[user]/public_html/wp-content/plugins/wp-shopping-cart/shopping_cart.php on line 306
This was working normally before; I don't know if the change was related to the upgrade in WP or the plugin, but I think that seems a likely culprit. Any suggestions on what to do next?
Share this post
Link to post
Thanks, Mike and Bruce.
It turns out CURL wasn't enabled on my server. The help desk was able to make the fix quite quickly.
Thanks,
Share this post
Link to post
