Cron?
Okay, potentially dumb question time. :lol:
First, is this the right place for a simple question about Cron jobs?
Second (if the answer to the first is yes), can I run any PHP script using Cron, or is it limited to running Cpanel backups?
Thanks for any help!
Dave
1) No (I sent you a pm about to where I moved this post).
2) While I have only used cron jobs to do cpanel backups myself, I believe you can use it for anything that needs to run on a scheduled time. Someone more knowledgeable about cron jobs will tell you more, so hold on. :lol:
