Trouble With Fantastico
Warning: tempnam() [function.tempnam]: open_basedir restriction in effect. File() is not within the allowed path(s): (/home/***/:/usr/lib/php:/usr/local/lib/php:/usr/local/sqmail:/tmp) in /home/***/public_html/lib/init/initlib.php on line 101
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/***/public_html/lib/init/initlib.php:101) in /home/***/public_html/tiki-setup_base.php on line 278
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/***/public_html/lib/init/initlib.php:101) in /home/***/public_html/tiki-setup_base.php on line 278
header already sent
That's what I got when trying to install TikiWiki. Somebody screwed up the installation script.
Edited by TCH-Thomas
Removed cpanelusername. Please do not post such info in the forum.
As a side note, I'm pretty sure this problem is not a Fantastico issue. I installed TikiWiki manually and had the same problem. But the helpdesk was able to help me.
From the TikiWiki forum I was informed that TikiWiki requires access to the /temp folder. Is this a permissions problem?
From memory on that error, you need to define where the 'tmp' folder is.
In lib/init/initlib.php ( within the tikiwiki installed directory ) add the line;
>$tempdir = "/tmp";
Near the bottom of that file to define the tmp directory ( so that ....
>function tempdir() {
			static $tempdir;
			if (!$tempdir) {
					$tempfile = tempnam(false,'');
					$tempdir = dirname($tempfile);
					@unlink($tempfile);
			return $tempdir;
becomes ......
			static $tempdir;
			$tempdir = "/tmp";
			if (!$tempdir) {
					@unlink($tempfile);
			return $tempdir;
Or open a ticket at the help desk and ask us to do it for you :)
