Using Pear Functions
mklappen
Hi
From reading the forums I've found that PEAR is installed on TCH servers but I'm not sure how to call from my PHP script.
I'd like to use the File_SearchReplace() function but I'm not where this module is located on the server to make the
require_once 'File/SearchReplace.php'; or include statement.
http://pear.php.net/manual/en/package.file...archreplace.php
Thanks
Mike
This post may help.
Thanks, I've added the following to my script but I still get an error:
<?php
ini_set('include_path', "/usr/local/bin/pear". ini_get("include_path"));
require_once ('File/SearchReplace.php');
Error:
Warning: main(File/SearchReplace.php) [function.main]: failed to open stream: No such file or directory in /home/mysite/public_html/test.php on line 6
Fatal error: main() [function.require]: Failed opening required 'File/SearchReplace.php' (include_path='/usr/local/bin/pear.:/usr/lib/php:/usr/local/lib/php') in /home/mysite/public_html/test.php on line 6
Thanks
Mike
