Accessing Horde
Please note that when resubscribing folders or viewing email via SquirrelMail, you most log in with your actual email address not your cpanel username.
Where do you go to log in using your actual Email Address?
I always just use to login straight from cpanel, I tried doing a google search using Horde, but all those links ask me for my username, not my email address.
This takes me straight to my regular horde account, the one I used before the server update (with just the username).
All I get from this link is a bunch of warning signs in an XML format (I never really used squirrelmail, just horde).
This one just takes me to my regular webmail login screen inside cpanel (It says you need the full email address, but when I click on those links, it acts as if I just logged in as I usually do, with my cpanel username).
So, none of those links ask for any of my email addresses, (except the last one, but it just mentions I need my full email) my regular one, or the folder-subscribed addresses I use.
The first link is where I think you should manage the subscriptions that this thread originally talks about.
Second link, is to the email user interface "squirrelmail", an interface I prefer, but I don´t think it can handle the imap settings.
Third link, is basically a cPanel lite version of the webmail combining login´s for both Horde and Squirrelmail.
On all of them you should be able to log in with any real email address you have set up in cPanel.
If you are receiving errors when trying to enter anyone of them, please submit a ticket and the techs will look in to it.
Just reread your original question. Do you use your cpanel username as your email address or have you set up real addresses/mailboxes in cpanel?
I'll be honest, I'm not exactly sure, I've never really messed around with email configurations much after launching them. But I do think that is not even set, I went to cpanel > Mail > Default address / and inside the boxes it says "No such User Here".
Even when I click on > Add/Remove/Manage Accounts / and it lists my email accounts, all the ones I created have the @site.com after them, except the primary account, this one is just my cpanel username.
EDIT: I suppose I don't even really know what I'm doing here, maybe I'd be better off opening a ticket.
Edited by jamestl2
All you need to do is go to http://toptenlisted.com/webmail and login with your email address and password for the account you want to check. Once you enter the email address and password you will be presented with two options. Whether to read your email with Horde or Squirrel Mail.
You are making it way more difficult than it is. If you have more than one email address that you check you will have to log into each one separately.
This is what I am trying to do, but when I follow that link, and go into horde, it never asks me for my email account, it doesn't "ask" for anything, it automatically takes me to the interface with my cpanel login name.
You should probably log out first. When you log back in to /webmail, it will ask you for a user/pass. Type in the email address you are checking along with the pass.
Its working now, Thanks :)
I didn't even realize it had stored my username on file, as I don't even remember setting that preference.
Also: The webmail link straight through cpanel didn't even offer that logout option, I had to go straight to http://toptenlisted.com/webmail
Edited by jamestl2
