Issues With Mysql Connections
Several of my users at spyderchat.com have been getting the following message intermittently:
Warning: mysql_connect() [function.mysql-connect]: User ***_donalex has already more than 'max_user_connections' active connections in /home/***/public_html/phpBB2/db/mysql4.php on line 48
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /home/***/public_html/phpBB2/db/mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /home/***/public_html/phpBB2/db/mysql4.php on line 331
phpBB : Critical Error
Could not connect to the database
We rarely have more than 40 people online at once.
Please advise,
Don
  • 2 weeks later...
sorry for not searching first - never mind - I am finding answers...
No, I did not find an answer which was corroborated by different people - I need help...
I got this:
Try adding the following to .htaccess
CODE
php_flag mysql.allow_persistent off
Open public_html/phpBB2/db/mysql4.php and locate the following code
>function sql_db($sqlserver, $sqluser, $sqlpassword, $database, $persistency = true)
and change it to
>function sql_db($sqlserver, $sqluser, $sqlpassword, $database, $persistency = false)
that should fix the problem.
Did adding that to your .htaccess file not help?
Or are you not sure where to add it?
I put it right after:
<IfModule mod_security.c>
SecFilterEngine Off
SecFilterScanPOST Off
</IfModule>
Is that correct?
