Javascript Help
jhollin1138
I feel like a javascript knucklehead here.
I am trying to implement the "Modal Dialog Box" script found here h**p://javascript.about.com/b/a/256836.htm. I have been able to get the front end of things working fine; it is the back end of things that isn't working.
I am working on a script, in PHP, that is pulling information together and generates one of three different reports. I am using the "Modal Dialog Box" to generate an interface for the user to select which of the reports they want to generate. When the user clicks 'OK', I want to pop-up a new window with their report. Here is my HTML code for the "Modal Dialog Box".
><div id="box" class="dialog">
<form method="post" name="printDialog" action="printWin('./print.php?id=4306&PrintSheet=', 'order');">
 <table align="center">
<tr><td colspan="2">Print Sheet: </td></tr>
<tr><td colspan="2"><input type="radio" name="PrintSheet" value="order" checked="checked" /> Order</td></tr>
<tr><td colspan="2"><input type="radio" name="PrintSheet" value="spec" /> Specification</td></tr>
<tr><td colspan="2"><input type="radio" name="PrintSheet" value="est" /> Estimate</td></tr>
<tr>
  <td> <input type="submit" name="submit" value="OK" onclick="hm('box');" /> </td>
  <td> <input type="reset" value="Cancel" onclick="hm('box');" /> </td>
</tr>
 </table>
</form>
</div>
Here is my javascript that is handling the pop-up window.
>MyPrintWin=null;
function printWin(linkName, printPageDefault) {
 if(MyPrintWin != null) MyPrintWin.close();
 for (var i=0; i < document.printDialog.PrintSheet.length; i++) {
if (document.printDialog.PrintSheet[i].checked) {
  var printPage = document.printDialog.PrintSheet[i].value;
 printPageLink = linkName + printPage;
 MyPrintWin = window.open(printPageLink, "printWindow", "width=700,height=500,menubar=no,resizable,toolbar=no,scrollbars");
When I click 'OK', the "Modal Dialog Box" is disappearing, but the pop-up isn't showing up.
If I change my javascript to:
>MyPrintWin=null;
 printPageLink = linkName + printPageDefault;
Everything works the way I would like, although obviously the value for the radio button is not being used.
Am I missing something here?
Here is an update.
I tried the following javascript code, still no luck.
>MyPrintWin=null;
var printPage = printPageDefault;
I also tried using onsubmit instead of action in my html form, no luck.
<form method="post" name="printDialog" onsubmit="printWin('./print.php?id=4306&PrintSheet=', 'spec');return false;">
<tr>
  <td> <input type="submit" name="submit" value="OK" onclick="java script:hm('box');" /> </td>
  <td> <input type="reset" value="Cancel" onclick="java script:hm('box');" /> </td>
</tr>
 </table>
</form>
</div>
Any help would be appreciated.
:) I finally got everything working. The solution came to me when I was giving the kids a bath. Instead of trying to figure out which radio button was picked and set a variable, just set a variable. This is what I came up with for the html section:
<form method="post" name="printDialog" action="printWin('./print.php?id=4306&PrintSheet=');">
<tr><td colspan="2"><input type="radio" name="PrintSheet" onclick="printPage='order'" /> Order</td></tr>
<tr><td colspan="2"><input type="radio" name="PrintSheet" onclick="printPage='spec'" /> Specification</td></tr>
<tr><td colspan="2"><input type="radio" name="PrintSheet" onclick="printPage='est'" /> Estimate</td></tr>
<tr>
</tr>
 </table>
</form>
</div>
Here is the java script:
>MyPrintWin=null;
function printWin(linkName) {
