Addition Problem With Php
jhollin1138
I am working on script and I am having the addition problems with PHP. Here is a sample piece of code that I am having a problem with.
><?php
$OverallTotal = 0;
for ($i=0; $i<count($arr_Multiplier); $i++) {
$arr_EstimateTotal[$i]['ItemType'] = $arr_Multiplier[$i]['ItemType'];
$arr_EstimateTotal[$i]['Multiplier'] = 1 + $arr_Multiplier[$i]['Multiplier'];
for ($j=0; $j<count($arr_Estimate); $j++) {
	if ($arr_Multiplier[$i]['ItemTypeID'] == $arr_Estimate[$j]['ItemTypeID']) {
		$arr_EstimateTotal[$i]['ItemTotal'] = $arr_EstimateTotal[$i]['ItemTotal'] + $arr_Estimate[$j]['Total'];
		$arr_EstimateTotal[$i]['MultTotal'] = ceil($arr_EstimateTotal[$i]['ItemTotal'] * $arr_EstimateTotal[$i]['Multiplier']);
		$OverallTotal = $OverallTotal + $arr_EstimateTotal[$i]['MultTotal'];
for ($i=0; $i<count($arr_LaborMultiplier); $i++) {
$arr_LaborTotal[$i]['LaborType'] = $arr_LaborMultiplier[$i]['LaborType'];
$arr_LaborTotal[$i]['LaborTotal'] = ceil($int_LaborTotal * $arr_LaborMultiplier[$i]['LaborMultiplier']);
$OverallTotal = $OverallTotal + $arr_LaborTotal[$i]['LaborTotal'];
// Building Table
echo '<table class="estimate">'."\n";
for ($i=0; $i<count($arr_EstimateTotal); $i++) {
echo '  <tr>'."\n";
echo '	<td align="right" colspan="8">';
echo str_replace($cfg['lang']['tag_total'],$arr_EstimateTotal[$i]['ItemType'],money_format($cfg['lang']['est_Material'], $arr_EstimateTotal[$i]['ItemTotal']));
echo ':</td>'."\n";
echo estimate_box('ETotal'.'_'.$arr_EstimateTotal[$i]['ItemTypeID'], $arr_EstimateTotal[$i]['MultTotal'], 50, 'Text', 7, 'right', 0, 0);
echo '  </tr>'."\n";
echo '  <tr>'."\n";
echo '	<td align="right" colspan="8">Total '.$arr_LaborTotal[$i]['LaborType'].':</td>'."\n";
echo estimate_box('LTotal'.'_'.$arr_LaborTotal[$i]['LaborTypeID'], $arr_LaborTotal[$i]['LaborTotal'], 50, 'Text', 7, 'right', 0, 0);
echo '  </tr>'."\n";
echo '  <tr>'."\n";
echo '	<td align="right" colspan="8">Total:</td>'."\n";
echo estimate_box('OTotal'.'_'.'T', $OverallTotal, 50, 'Text', 7, 'right', 0, 0);
echo '  </tr>'."\n";
echo '</form>'."\n";
I am pulling data into the arrays "$arr_Multiplier", "$arr_Estimate" & "$arr_LaborMultiplier" and variable "$int_LaborTotal" from a MySQL database. The data is all correct. The problem is the value for "$OverallTotal" is incorrect. PHP is saying 4193, but when I add the values I get 4075 (791+269+810+585+1620=4075). See this link to the stripped down source code of the output (I have a screen-shot of the output but I couldn't get it to attach it). Some items don't have the problem, while others do.
Does anyone have any ideas?
:oops:I found my problem. Replacing the similar section of code in my first post with the code below, fixes the it.
