Using Joomla With Community Builder And Task Hopper
bullfrog007
Hi all,
I completely new to Joomla, but I'm trying to learn through this site. I have used plone but it has been quite some time since I've done any coding. I am trying to build a volunteer community web site using Community Builder and Task Hopper. Has anyone had any experience with these two components/extensions? Any words of advice? Finally, about how much room do I need for about 100 members (I'm only going to allow them to post a picture of themselves and no large content.)
Thanks!
jeremy
Welcome to the forums Jeremy :)
Sorry, I have not used any of those tools but hang tight and maybe one of our members that has will lend some advice.
As for how much space do you need don't worry about it. You can upgrade your plan at anytime by opening a ticket with the help desk. So you can start small and upgrade as needed.
You are best to check on the Joomla forums for support with Addons and Components as they would have more traffic about them. I use Joomla but not the components you are referencing. Also keep in mind that the Beta release for Joomla 1.5 has been released so it shouldn't be too long before a stable release of it is in the wind, probably 1st quater new year. Then it any sites will need to be ported over and that is still in discussions as the new version is a complete rewrite of the coding and slightly different admin structuring as well. The other thing there will be components and addons that need to be rewritten as well to work with the new version.
