Ftp Question
Kaula
I'm not sure if this is a help ticket issue, so I thought I'd ask here first. Sometimes I have to transfer several hundred files too and from my website at a time, pictures or schoolwork or whatever... when I do this, I have to do it in sections, because after a few minutes of either uploading or downloading a ton of files with an ftp client (smartftp, dreamweaver, gftp are the ones I use), the server will stop responding for around 30 seconds to a minute and I'll have to reconnect and start over. Also during that 30-60 seconds I cant reach my website via http either. So I guess my question is, Is there any sort of protection inplace that might be limiting the amount of files that can be transferred in a given amount of time?
Thanks,
Paul
I had similar problems on a dial-up, I think it was my ISP or poor connection.
I had to zip up my files and let file manager uncompressed them.
For downloading, I found it quicker to use
cpanel > backup
download a home directory, and uncompressed on my computer.
On cable I still zip large amounts of files for upload as its much quicker.
What you might do is coordinate with a friend who has different connection to the Internet. Replicate your file-transfer problem. When you have site access issues, have your friend attempt to access your website. If the site is slow for your friend, likely the problem is server side. If it is not slow, the problem likely is with your ISP and/or connection.
Problems like this are annoying because they can be quite difficult to narrow to the actual cause.
telcor Ive been able to reproduce it from a friends house and from school.
Normally happens when I transfer a large amount of files, maybe 200+. though the timing of when it happens seems random along with how long it becomes unaccessible seems to be random.
Here is an example of what happens after file transfer fails,
http://www.kaulaiscool.com/ftp_example/ftp_example.html
its not imporant any longer
Weird. If it didn't do anything to your website I would call it a bug in the FTPd server software.
