jtrai491 Posted August 10, 2006 Posted August 10, 2006 I am having problems now not only publishing within FrontPage but now my cart software has taken a fit. I am contemplating redoing the entire site over. Before I do it I thought I wanted to ask for some advice. 1. I was looking at an template from ECOMMERCE with a shopping cart. It doesn't use FP Extensions, which I know is part of my problem. Has anyone used these templates from Ecommerce? 2. If I decide to redo the entire site, should I have my current space cleaned out and start over like new ?? I have done a lot a testing with other packages and my house cleaning stinks, so there is alot of crap out there. Opinions are greatly appreciated, thanks Joe Trainor www.keystone-embroidery.com Quote
stevevan Posted August 10, 2006 Posted August 10, 2006 While I always feel that redoing a site is an absolute last resort, you might want to check out the e-commerce offerings through fantastico. Many of our family members use them, so there would be a lot of help available for the asking. Quote
TCH-JimE Posted August 10, 2006 Posted August 10, 2006 If your starting from scratch, then I would have everything removed, it makes things easier in the future. Remember to make sure you have a backup of everything and have it downloaded. Help desk should be able to "re-fresh" your account I believe. I would also look at fantasico, there are many useful scripts in there JimE Quote
Samrc Posted August 11, 2006 Posted August 11, 2006 I agree. Starting fresh would be your best bet if you are planning to rebuild. Put in a help ticket and ask them to reset your account for best results. I have not tried the templates you mention. But I have used some of the Fastastico installed pieces and find it is so easy to setup and update. Quote
reddwine Posted September 5, 2006 Posted September 5, 2006 Im making my site in FrontPage. Is there a tutorial to show me how step by step. Ive used front page before, but I didnt initially set up the passwords, and the site to upload to. This is what I need help with. How do I start ??? Thank you for your help. Barb Quote
TCH-Bruce Posted September 5, 2006 Posted September 5, 2006 I think the FrontPage Tutorial page will help you out. Quote
