mythusmage
Lifetype Help!
I'm trying out different blogging engines. One of them being Lifetype. Most of the time I can download to my machine, upload to TCH, and install. Not with Lifetype. I have an old, OS 10 incapable iMac. OS 9 can't handle long file names. So Lifepath's long file names get truncated. The result is, file names Cpanel doesn't recognize, and won't rename because, according to Cpanel, they don't exist. Makes installing Lifepath impossible.
So I come to the TCH community with a plea for assistance. I can provide the URL, username, and password for my account. All I ask is that some kind person upload Lifetype for me. I can handle installation from there. My thanks to whoever helps.
Share this post
Link to post
Can you download the zip file to your computer and upload it to your webspace and then unpack it with cPanels file manager?
I would really be careful about giving out your information to anyone other than a TCH staff member. As helpful as we all are, you never know.
Share this post
Link to post
Download the tar.gz file from this page. Upload it to the server in your public_html folder and extract it.
It will create a folder called lifetype-1.0.4, you can just rename the folder what ever you like after it's extracted.
Share this post
Link to post
I'll second the WordPress recommendation. :group:
Share this post
Link to post
The good news is, I downloaded Lifetype 1.0.5.zip, then uploaded Lifetype 1.0.5.zip to my site. Followed instructions, and got started on installing.
However, I seem to be having some trouble connecting to the server. I put in the info, hit "next" and get:
Exception message: mysql_num_rows(): supplied argument is not a valid MySQL result resource
Error code: 2
-- Backtrace --
/home/-----/public_html/lifetype/class/database/adodb/drivers/adodb-mysql.inc.php(426): mysql_num_rows
/home/-----/public_html/lifetype/class/database/adodb/drivers/adodb-mysql.inc.php(364): adodb_mysql._getdbdefaultencoding
/home/-----/public_html/lifetype/class/database/adodb/adodb.inc.php(414): adodb_mysql._connect
/home/-----/public_html/lifetype/wizard.php(666): adodb_mysql.connect
/home/-----/public_html/lifetype/wizard.php(916): connectdb
/home/-----/public_html/lifetype/class/controller/controller.class.php(309): wizardsteptwo.perform
/home/-----/public_html/lifetype/wizard.php(1828): controller.process
Exception message: mysql_fetch_row(): supplied argument is not a valid MySQL result resource
Error code: 2
-- Backtrace --
/home/------/public_html/lifetype/class/database/adodb/drivers/adodb-mysql.inc.php(430): mysql_fetch_row
/home/------/public_html/lifetype/class/database/adodb/drivers/adodb-mysql.inc.php(364): adodb_mysql._getdbdefaultencoding
Any ideas, or should I open a trouble ticket?
Update: Call me clueless but, would I use "localhost" or "localhost" with parentheses or such like. Quotes maybe?
EDIT: TCH-Bruce - I have removed your TCH account name. Please don't post that in the forums.
Edited by TCH-Bruce
Share this post
Link to post
As the help desk does not support third party scripts,
have you tried the Lifetype site for support ?
I see they have a wiki for installation help.
Share this post
Link to post
Not knowing how the installation routine works for this product did you create a database, create user and add the user to the database?
Share this post
Link to post
Here is what I did to get this working;
Downloaded file
Uploaded to my webspace
Unpacked using File Manager
Renamed folder to "life" (for my ease of use)
Created database in cPanel
Created user for said database
Added user to database
Navigate in your File Manager to yourtchdomain/life/config and change config.properties.php permissions to 777
go to yourtchdomain.com/life/wizard.php
Fill in
"localhost";
"yourtchdomain_admin2";
"password";
"youyrtchdomain_life";
Next
Next
Fill in form
Next
Fill in more things
Select a template
Next
Remove wizard.php file and change permissions on config.properties.php back to what they were
Welcome to LifeType
Share this post
Link to post
Bah! I had ten minutes to kill so I thought I would try it out. Being a WP user, it was not intuitive to me at first. Took a second to find out where everything was. My initial impression is that it is somewhat simplistic yet it seems to have potential. I would need to play around with it to be able to give a full "Rob" review.
Share this post
Link to post
I look forward to the full Rob Review.
I'm mostly interested in its capabilities as a multi-blog hosting platform. Downloaded it, just haven't taken the ten minutes to install it. Easier to just let Rob fill me in....
Share this post
Link to post
OK,
I had a better look at things and I think the simplistic was maybe a poor choice. This really looks pretty robust. There are a lot of features and I think it would make a great multi-blog, even one for a single user, though I think it might be overkill if used as that.
There seem to be a fair number of plugins and templates available for it and one can custom create their own if they wish. The templating system is based of Smarty so there may be a learning curve that one has to overcome if they are used to other blog scripts.
Although I am not ready to leave WP as I am satisfied, should I ever feel the need to move beyond it, I will be sure that this is the first place I go.
Share this post
Link to post
Finally got around to installing LifeType this weekend. Had one or two bumps but it is up and running without too much swearing.
My take is that this is a great script to use if you want to host multiple blogs easily or allow people to sign up for their own blogs (a la Blogger). There are tons of options, you can upload templates so users have choices, and admin control for the whole thing is laid out pretty well. Documentation and user forums seem to be fairly well organized and I didn't have much problem finding answers to some question. For a single blog installation I'd be inclined to stick with WordPress.
I just want to throw in the disclaimer that in no way am I suggesting you attempt to start up the next Blogger on one of our shared servers - we do monitor loads so it won't last long. Also, you are responsible for any usage on your account, so anything your visitors say, do, or upload may come back to you.
That said, this is a pretty cool script and worth checking out.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
