way2kool Posted May 12, 2006 Share Posted May 12, 2006 I need some help. I need to set up a forum but not sure how. I downloaded the phpbb one but it gave me a bunch of files and folders I don't know what to do with. I don't know much about forums beside the one that bravenet has and I don't like those. To many popup. Can anyone give me some insight on how to get and set up a forum. I design a website for a publisher and they want a forum, so could use some help. Patty Quote Link to comment Share on other sites More sharing options...
charle97 Posted May 12, 2006 Share Posted May 12, 2006 Build a phpBB Forum in 5 Steps; it's a bit dated, but the tutorial should give you a rough idea. look for a readme/manual file at the top level of the installation package. Quote Link to comment Share on other sites More sharing options...
abinidi Posted May 12, 2006 Share Posted May 12, 2006 The very easiest way is to use the installer in Fantastico on your cPanel control. Click on Fantastico, then install whatever software you want. There is one forum option there, if you are interested. Best of all, you don't have to do anything else! Quote Link to comment Share on other sites More sharing options...
cajunman4life Posted May 13, 2006 Share Posted May 13, 2006 I believe SimpleMachines is also offered through Fantastico (still at work so I can't check it right now... firewall rules and all). There are those out there who feel SMF is a bit more powerful/flexible than phpBB (as well as a bit more secure). No bias here Quote Link to comment Share on other sites More sharing options...
chatbug Posted May 13, 2006 Share Posted May 13, 2006 Simple Machines Forum, SMF (1.0.5 [Patched-1]), seems to be the only forum/discussion board software offered through Fantastico at the moment. Quote Link to comment Share on other sites More sharing options...
cajunman4life Posted May 13, 2006 Share Posted May 13, 2006 1.0.5? I'd highly recommend downloading the latest version from SimpleMachines.org and installing it. It is currently 1.0.7 (or 1.1 RC2 is available for testing), which includes several security fixes over 1.0.5. As with anything you install from cpanel, same goes for Fantastico. Usually they are a version or two behind the upstream vendors. Make sure you keep all your scripts up to date to avoid having your account compromised. Quote Link to comment Share on other sites More sharing options...
Kevan Posted May 13, 2006 Share Posted May 13, 2006 Once you install SMF through Fantastico you can use the SMF Admin panel to upgrade to the latest version. I think it takes 2 clicks. Quote Link to comment Share on other sites More sharing options...
stevevan Posted May 13, 2006 Share Posted May 13, 2006 Just a reminder that no matter which forum you decide to use, make sure you have the latest and greatest version to keep out the pesky hackers and spammers! Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted May 13, 2006 Share Posted May 13, 2006 Simple Machines Forum, SMF (1.0.5 [Patched-1]), seems to be the only forum/discussion board software offered through Fantastico at the moment. However phpBB can be installed from cpanel > Addon Scripts (version 2.0.19) So you will also have to upgrade it to the latest version by downloading changed files. Yes definitely upgrade your forums, in fact subscribe to their forums upgrade notice. Quote Link to comment Share on other sites More sharing options...
chatbug Posted May 13, 2006 Share Posted May 13, 2006 Oops... thanks for pointing that out Don! Interesting, though... why is the cpanel icon called "Scripts Library", and inside it's actually called "Addon Scripts"? Is the "InvisionBoard 1.2" (available at the same place) the same as Invision Power Board? Or is it a different product? Quote Link to comment Share on other sites More sharing options...
cajunman4life Posted May 13, 2006 Share Posted May 13, 2006 Oops... thanks for pointing that out Don! Interesting, though... why is the cpanel icon called "Scripts Library", and inside it's actually called "Addon Scripts"? Is the "InvisionBoard 1.2" (available at the same place) the same as Invision Power Board? Or is it a different product? It's the same thing, but outdated. 1.2 was the last "free" version that IPS released. I think they are on 2.3 now, which you have to pay for. I wouldn't recommend using 1.2 as there are quite a few vulnerabilities. Quote Link to comment Share on other sites More sharing options...
