Vintage Lover
Installing 3rd Party Shopping Cart-help
I was told by the vendor that I need to ftp the files from my desktop rather than unzip and extract in cPanel. There are a ton of files!
any better way to do this than file by file using the cPanel file upload?
Thanks.
Sandra
Share this post
Link to post
I would like to know why you can't upload the zip file and extract?
That is the most efficient way.
What cart is it?
The desktop is not a good place to put files.
Share this post
Link to post
I'm not sure why it won't extract, but I tried it and it won't extract. I've extracted files before, and this time it won't work.
The cart is CKgold. i contacted them about the extraction problem and they said I need to save it to the desktop and FTP the files. This is just the trial version. Wonder if that has something to do with it.
I use Firefox as my browser now. I'll try their FTP software.
Sandra
Share this post
Link to post
That message occurs when a zip file is not recognized on the server. I've seen this message myself before. When I do, I extract the archive on my PC and then Zip it back up using WinZip and upload it to the server. I've never had a problem doing it this way.
Share this post
Link to post
I generally extract to a folder of the same name I want to use on the server
then make my edits and zip up the folder.
Upload to public_html and extract so the folder structure is kept intact.
The desktop is a folder in windows and not a safe place to keep files. :)
Share this post
Link to post
Ah, I should have mentioned Fetch in the list. Sorry.
Glad you got it working though. :ph34r:
Share this post
Link to post
