Web Design Programs Supported
nhlee
I am trying to find out what design programs TCH supports.
I have always used CuteSite Builder but have just designed a new site with Web Easy Professional 6.
For some reason I am having trouble publishing my site.
Where can I find information on the programs supported by TCH?
Thank you,
Lee
Hi Lee,
It should not matter what web site program you use on your computer.
Did you set up the publish settings the same way you did in CuteSite Bulider
or like in an FTP program
don't forget the remote folder where your files go is the public_html folder
or for WebEasy it's called initial remote folder
in the Remote Access" page of the Connection Profile screen.
so put public_html in the Inital Remote Acess field
Hi Lee,
Thank you both for responding so quickly.
Yes, I did set up initial remote folder to public_html and I set up everything else the same as I did for CSB but nothing happens and I get the following message:
THE LAST MESSAGE FROM THE SERVER IS
User xxxxxx has group access to: xxxxxxx
OK. Current restricted directory is /
Do you have any idea what that means?
Thanks again,
Lee
I installed the trial version
When you get to that message box
its telling you it has connected,
click on the close button and continue from there.
Interesting program, but inefficient.
It republishes all pages and images every time you make a change.
You would be better to preview to a folder
and then use an FTP program to upload your changes.
(when trying to publish for a third time the program hung up and quit on me :)
(off to remove it)
