Ispell
Ojster
Hello,
I did not know in which forum to post this and I think this is the closest.
I have a question about International Ispell. This is a free script which enables you to check for spelling errors. I am running MovableType script and would sure like spelling feature. In order this to work you need to know the path to International Ispell on the system.
I did not find it mentioned anywhere on this forum and on your pages. What I would like to know is whether you have it installed or if not, if there is a chance that you would install it? More info about this script can be found here: http://fmg-www.cs.ucla.edu/fmg-members/geo...off/ispell.html English and American dictionary are default and I am sure many users of MovableTpye would find it usefull.
Thank you for your info.
Best regards,
Peter
If you want it, you would have to install it yourself. They provide a tar.gz file for you to download, and then upload to your TCH web site. Then simply use your CPanels' File Manager to unpack and install the tar.gz file.
One warning, though --- it looks like the latest version of ISpell is dated Aug-2001, or almost two years old. Does not look like there's much, if any, technical support for the product.
I suppose I'm impressed that they ported it to the Commodore Amiga. Are you sure this is something you want??? Who recommended it to you?
-kw
Hello,
Thank you for your reply. I did not know that I can install it myself - I thought you'd need administrator rights to do it.
This program is needed by a plugin "Spelling" which can be run in MovableType. For those interested in this more info can be found at: http://mt-plugins.org/archives/entry/speling.php
It is a great utility for weblogs since you can correct spelling errors before publishing your entry without the need for any external software.
I will try and install it myself and see what happens.
Well, I am checking the readme file and I came to the following:
"Ispell is quite portable (thanks to many people). If you speak
American English and have a BSD-like system, you may be able to
get away with simply typing "make all" to make ispell and a
dictionary, all configured to be installed in /usr/local/*. If
you have a USG (System V) system (such as Linux, IRIX, or HP-UX),
you will at least have to copy "local.h.samp" to "local.h", then
add "#define USG" to local.h before compiling. Be sure you have
at least 10 MB of free space in /tmp, or set your TMPDIR
environment variable to point somewhere with that much space."
Can I do that? "make all" command I mean? Is this possible via Control Panel?
Thanks!
Best regards,
Peter
Ooops --- the program is written in 'C' and they want you to "compile" the program. That's a whole different story! I would suggest dropping a help ticket to tCH support and askign if the ability to both compile and install a third party 'C' program is possible, Provide the same information as you did here.
-kw
Hello,
I know about W.blogger - I tried it already but the problem is you can not use all the functionality of MovableType. Otherwise it is a great probgram but it also does not allow for users that post comments to check spelling.
kweilbacher,
I will post the support ticket and see what they say. I guess it would be a good additional feature also for other users of MovableTpye.
Best regards,
Peter
Hello,
I just posted a support ticket but when I got that automated reply it says:
"Please be advised the help desk does not offer support for the following: HTML coding issues, 3rd party script installation or support, PHP coding support, Shopping Cart Software Support, Graphic Design Issues, or any non related server side issue."
This is actually not a 3rd party script - it is 3rd party software ... ok, we'll see - I will let you know whether I was lucky :)
1. I understand, and I'm sure you can, too, that TCH cannot be in the business of providing support for 3rd party software programs opr scripts.
2. That's why I carefully worded my suggestion for you to ask the Help desk, and I quote:
.. ask if the ability to both compile and install a third party 'C' program is possible"
To my way of thinking that is a "server related question", and is quite different than asking som,ething like "how do I get ISpell installed on my TCH web site?".
So, as you said ... let's wait and see!
-kw
