Sarah
Problem With Php Preg_match Function
Good afternoon!
I am writing a function to try and validate a phone number field using a preg_match function. I am having a hard time understanding how it works but this is what I've got so far. It should accept an entry in this format: xxx-xxx-xxxx and if it isn't, then it should return false.
>function checkPhone($element){
 $phoneno = trim($element);
 return !preg_match("(^(.*)[0-9]{3})(.*)([0-9]{3})(.*)([0-9]{4}$)", $phoneno);
I call this function in my code like this:
>if (!@checkPhone($_POST['phoneno'])){
 $msg=$msg."Please enter a valid phone number.<br>";
 $flag = "NOTOK";
}else{
....blah blah blah this code is if the phone number checks out ok
But when I run the function in my debugger, it shows me this warning:
Debug Warning: validation.php line 29 - preg_match(): Unknown modifier '('
Any ideas?
Thanks in advance.
Share this post
Link to post
Don't know about your code but here is an example I found that does what you want.
>A very simple Phone number validation function.
Returns the Phone number if the number is in the xxx-xxx-xxxx format. x being 0-9.
Returns false if missing digits or improper characters are included.
function VALIDATE_USPHONE($phonenumber)
if ( (preg_match("/^[0-9]{3,3}[-]{1,1}[0-9]{3,3}[-]{1,1}
 [0-9]{4,4}$/", $phonenumber) ) == TRUE ) {
  return $phonenumber;
} else {
  return false;
Share this post
Link to post
Bruce-
First off, thanks for the code.
I tried your function and wrote this to call it:
>if (!@VALIDATE_USPHONE($_POST['phoneno'])){
 $flag = "NOTOK";
When I entered in my form 123-456-7890 as the phone number, it should have let me submit the form since that is a valid format.
However, it said "Please enter a valid phone number." Everything I was putting in was giving me the error.
What did I do wrong? Is it something with the return value?
Share this post
Link to post
I'm a VERY NEW php person, but I would probably try putting in a javascript popup or something for testing purposes that will display the value of the $phonenumber variable.
I'd want to know how the information was being entered into the variable to see if that helped to illustrate where the problem was.
I dunno. Bruce (or somebody else) will probably be able to help you more than that. Just a small suggestion for a PHP beginner. (Who knows. Maybe you already thought of that and this is way over my head...)
Share this post
Link to post
Bruce-
Sorry, I found the code snippit in another forum. I am a PHP noob as well.
Maybe one of our more well versed PHP members can point you in the right direction.
Share this post
Link to post
I believe it has something to do with the returning value. But I'm not quite sure how to handle it...
Share this post
Link to post
Well, once again I've figured out my problem. I think it was a combination of the returning values and how the code snippet was originally written. I revised the function to this:
>function VALIDATE_USPHONE($phonenumber){
 if ( (preg_match("/^[0-9]{3,3}[-]{1,1}[0-9]{3,3}[-]{1,1}[0-9]{4,4}$/", $phonenumber) ) == TRUE ){
  		return TRUE;
} else{
	return FALSE;
and my function call to this:
$flag = "NOTOK";
And it worked fine. Thanks for everyone's help.
Share this post
Link to post
Glad you got it working :notworthy:
And if you are only interested in US phone numbers you can tweak it to
 if ( (preg_match("/^[3-9]{3,3}[-]{1,1}[0-9]{3,3}[-]{1,1}[0-9]{4,4}$/", $phonenumber) ) == TRUE ){
	   return TRUE;
} else{
	return FALSE;
No US phone number begin with 0 or 1 in the area code.
Share this post
Link to post
