Problem Setting Up Cron Job
Miriam
I have configured the dbsender.php script with the top line of #! /usr/bin/php -q as per the instructions within the script.
I have set up the cron job as:
php -q /home/USERNAME/dbsender/dbsender.php >dev/null based on info from other threads.
I'm requesting the file to be sent by email.
I'm receiving an email that says:
/bin/sh: dev/null: No such file or directory
I have uploaded the script above html_public into a directory called dbsender.
I have chmoded the dbsender directory to 770 and the dbsender.php file to 770.
Any help will be appreciated.
Thanks
I use dbsender and here's how I have mine configured.
I did not add the #! /usr/bin/php -q to the top of the file as you did.
My dbsender folder is 770, the script itself is 644
My cron command is:
>/use/bin/php -q /home/USERNAME/dbsender/dbsender.php
I'm now receiving two emails, one says the database file has been backed up and is attached, and the other contains this message:
sh: /dbsender/fDATABASE_NAME-113005-0253pm.sql: No such file or directory
tar: DATABASE_NAME-113005-0253pm.sql: Cannot stat: No such file or directory
tar: Error exit delayed from previous errors
sh: ncftpput: command not found
The file attachment is actually empty.
Any ideas what's wrong?
Thanks
Are you trying to use FTP? I am sending via email.
Check also to make sure you configure the following variables correctly.
>// configure your database variables below:
$dbhost = 'localhost'; // Server address of your MySQL Server
$dbuser = 'cpanelname_user-for-db'; // Username to access MySQL database
$dbpass = 'password-for-database-user'; // Password to access MySQL database
$dbname = 'cpanelname_databasename'; // Database Name
I'm trying to send via email.
I have checked the configuration, and I think I have it correct, as you have shown, with both the cpanelname as the prefix then an underscore, then the actual database/user name.
Do you have any idea why it can't actually write anything to the file?
Miriam
