Guest marqui Posted May 30, 2003 Share Posted May 30, 2003 this post says imap is not used http://www.totalchoicehosting.com/forums/i...hl=imap,and,pop and this post says it is http://www.totalchoicehosting.com/forums/i...=ST&f=15&t=2350 the first post says neo and horde are imap clients, so does that mean if i sign up i can check my email using outlooking with imap.****? sorry for bringing this subject up again, but i just want to eliminate the ambiguity of the post that says imap is not used. thanks. Quote Link to comment Share on other sites More sharing options...
rayners Posted May 30, 2003 Share Posted May 30, 2003 Okay, just to clear a few things up initially (based on what I read in those threads), here are the protocols involved in all this: Mail Access Protocols POP - downloads email to your PC IMAP - gives you access to your mailbox from a "remote" location. All the mail is stored on the server. Think of it like an email "browser" [*]Main Transport Protocols SMTP - Simple Mail Transport Protocol is used to transfer mail between domains. Think of it like the Post Office. It handles the mail from when you drop it in the mail box (i.e. hit the send button) to when it gets to the recipient's mailbox. (this protocol is required for email to work at all) All that said. I know for a fact that we support POP. We do support IMAP as well, though I don't know off the top of my head if we support it from remote locations (which, considering what the protocol is inteded for, might be a little silly. though if used or implemented improperly it has the potential to be a bandwidth hog). A number of people (myself included, though I don't use it) have installed SquirrelMail in their accounts, which does require IMAP to work. After a quick perusal o the NeoMail site, it seems to require local access to email mailboxes (i.e. neither POP nor IMAP). Horde's email client uses IMAP. Okay, I just manually logged into the IMAP server for my domain (mail.rayners.org) from my own machine, so it would appear that you would be able to use Outlook and IMAP to check your email. Quote Link to comment Share on other sites More sharing options...
TCH-JimE Posted May 31, 2003 Share Posted May 31, 2003 Hi, My bad, I misunderstood the question! Jim Quote Link to comment Share on other sites More sharing options...
matman Posted June 2, 2003 Share Posted June 2, 2003 I tried accessing my TCH mail for my domain with IMAP before and was unable to do so. Gurus -- do we have IMAP access or no? If you say it should work, I'll give it another try. Quote Link to comment Share on other sites More sharing options...
KevinW Posted June 2, 2003 Share Posted June 2, 2003 Matman - what app are you using to do your IMAP access? -kw Quote Link to comment Share on other sites More sharing options...
KevinW Posted June 2, 2003 Share Posted June 2, 2003 FWIW, I telnet'd to the IMAP service running on my TCH server Trying 66.246.35.30...Connected to kwsupport.com. Escape character is '^]'. * OK [CAPABILITY IMAP4REV1 LOGIN-REFERRALS AUTH=LOGIN] server5.totalchoicehosting.com IMAP4rev1 2002.325-cpanel at Mon, 2 Jun 2003 13:55:47 -0400 (EDT) Also, here is a guide on using IMAP and Linux: http://www.linuxgazette.com/issue35/jao.html -kw Quote Link to comment Share on other sites More sharing options...
matman Posted June 2, 2003 Share Posted June 2, 2003 I was using Outlook Express. I even tried using a raw connection like you did and still had no luck, but I'll try again and post the result here. Quote Link to comment Share on other sites More sharing options...
matman Posted June 2, 2003 Share Posted June 2, 2003 Worked nice and smooth this time. I have no idea why not before, but anyway it is great now. This will make it much easier to peek at my regular e-mail from my work PC. Quote Link to comment Share on other sites More sharing options...
KevinW Posted June 3, 2003 Share Posted June 3, 2003 Glad to hear it's working! -kw Quote Link to comment Share on other sites More sharing options...
