kingram Posted August 25, 2005 Share Posted August 25, 2005 (edited) I ha d a tough time to validate my Wp blog after using a quote plug-in. I am sure there are couple of professionals out there who can hint on that. I have almost tried what I knew or there is a tiny trick there! Thanks Edited August 25, 2005 by kingram Quote Link to comment Share on other sites More sharing options...
borfast Posted August 25, 2005 Share Posted August 25, 2005 Hi Kingram. I don't use WP in a long time, so I may be wrong but I think the only way you have to prevent that is to change the plugin's output code directly, so that it will produce compliant XHTML code. What was the solution you found? Quote Link to comment Share on other sites More sharing options...
kingram Posted August 25, 2005 Author Share Posted August 25, 2005 Hi , Some part of the class in the funtion (plug in) was embded in " ". So I just removed it and it works fine now. Thanks Hi Kingram. I don't use WP in a long time, so I may be wrong but I think the only way you have to prevent that is to change the plugin's output code directly, so that it will produce compliant XHTML code. What was the solution you found? <{POST_SNAPBACK}> Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted August 25, 2005 Share Posted August 25, 2005 Glad you found a solution Quote Link to comment Share on other sites More sharing options...
