surefire Posted August 10, 2005 Share Posted August 10, 2005 I came across a link recently that was http://sub1.www.sitename.com I'm assuming the www in this case is a directory or sub1 where sub1 is the subdomain? Anyone have any ideas on this? I'd like to have the ability to set up links in a similar fashion. Quote Link to comment Share on other sites More sharing options...
TweezerMan Posted August 10, 2005 Share Posted August 10, 2005 I've never done a double subdomain, but it looks like you can set them up in the Subdomains section of your CPanel. To set up http://sub1.sub2.your-TCH-domain.com, you'd first create the sub2.your-TCH-domain.com subdomain. Then you'd select sub2.your-TCH-domain.com in the drop-down box next to the "Add" button and create the sub1 subdomain, which I think would give you sub1.sub2.your-TCH-domain.com. I guess you can give it a try and see if it works. Quote Link to comment Share on other sites More sharing options...
TCH-Rob Posted August 10, 2005 Share Posted August 10, 2005 Last I heard when this was discussed several months ago, this was not available on TCH servers. Quote Link to comment Share on other sites More sharing options...
surefire Posted August 10, 2005 Author Share Posted August 10, 2005 Thank you Rob and David. I'll test it out... maybe I'll get lucky. I can't tell you how many times I've discovered something new just by attempting things that you just 'knew couldn't work'. Quote Link to comment Share on other sites More sharing options...
abinidi Posted August 10, 2005 Share Posted August 10, 2005 I tried this, and indeed, it does not work. When you are in cPanel, if you try to add the subdomain "test" to "subdomain.example.com", cPanel will tell you that the creation was sucessful, however, if you try to access http://test.subdomain.example.com, it doesn't work. If you look at your folder structure, you will discover that cpanel created the "test" folder in /public_html/ directory, NOT the /public_html/subdomain/ directory. But you can't simply use "test.example.com" because that doesn't work either. You can only access the contents of this folder by going to example.com/test. So, while cPanel TELLS you that the subdomain creation was successful, it won't work when you try to actually use it. Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted August 10, 2005 Share Posted August 10, 2005 sub.sub.domains are not supported here. Quote Link to comment Share on other sites More sharing options...
surefire Posted August 11, 2005 Author Share Posted August 11, 2005 Well, at least I have my answer. Thank you for being so helpful, gang. Quote Link to comment Share on other sites More sharing options...
