section31 Posted May 27, 2005 Share Posted May 27, 2005 (edited) I can't get ImageMagick to work on server49 anymore. It was working just a few days ago, and now it doesn't. I have several accounts with you all and the same scripts work on server23 so i'm almost sure its not my code. I've already submitted a helpdesk ticket and they replied saying nothing is wrong with image magick and recommended I post my problem here. Ok, so check this out. ><? echo shell_exec('whereis convert'); // Where is the path to convert/imagemagick echo '<br />'; echo shell_exec('convert -version'); // What is the version of imagemagick running exec('convert image.jpg -resize 50% new.jpg'); // Create a new image half the size of the original ?> Both of these are in a directory thats chmodded to 777. On server 23, everything works fine. It outputs both the pathname and version and it creates the new image. convert: /usr/X11R6/bin/convert /usr/bin/X11/convert /usr/local/bin/convertVersion: ImageMagick 5.5.6 04/01/03 Q16 http://www.imagemagick.org Copyright: Copyright © 2003 ImageMagick Studio LLC On server 49. It outputs the pathname, doesn't output the version and doesn't create the new image. convert: /usr/local/bin/convert Edited May 27, 2005 by section31 Quote Link to comment Share on other sites More sharing options...
TweezerMan Posted May 27, 2005 Share Posted May 27, 2005 I agree that it looks odd. One thing I'd suggest - modify your shell_exec() command so errors are redirected to standard output (where your script can capture them): >echo shell_exec('convert -version 2>&1'); // What is the version of imagemagick running As your script is, you won't see any error messages from commands run by shell_exec() if one occurs. With the above change, error messages will be output to the page. Quote Link to comment Share on other sites More sharing options...
TweezerMan Posted May 27, 2005 Share Posted May 27, 2005 I took a look at phpinfo() on server 49, and this is what it's showing for the PATH environment variable: >/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin What's notable here is that the /usr/local/bin and /usr/local/sbin directories are not in your PATH environment. Since 'convert' is only available in the /usr/local/bin directory, you'd have to specify a full path to execute it: >echo shell_exec('/usr/local/bin/convert -version'); I'd be willing to bet that if you run your script after modifying it like I suggested above, you'll see an error like the following: >sh: line 1: convert: No such file or directory ...because 'convert' isn't in any of the directories listed in the PATH environment variable. I'd suggest reopening your Help Desk ticket (or submit a new one) and request that /usr/local/bin and /usr/local/sbin directories be added to the PATH environment variable. Quote Link to comment Share on other sites More sharing options...
section31 Posted May 28, 2005 Author Share Posted May 28, 2005 You nailed it david... Thanks and I will notify the techs. Quote Link to comment Share on other sites More sharing options...
