prabhath Posted May 11, 2005 Posted May 11, 2005 See tutorial on my previous post here: http://www.totalchoicehosting.com/forums/i...ndpost&p=129351 Quote
prabhath Posted May 11, 2005 Author Posted May 11, 2005 In addition, you might get this wierd error message on the top of phpWiki on the first visit to a page (it disappears after a refresh): >lib/Request.php:136: Warning[2]: ob_start(): output handler 'ob_gzhandler' cannot be used after 'URL-Rewriter' The solution to this can be found Here or just keep reading. 1. Find your index.php file in the phpwiki directory 2. Find the line that states: >define('COMPRESS_OUTPUT', false); 3. Un comment the line, or make sure that the setting is indeed false. That should do it, the explanation off the website linked above is: When Apache is configured to deliver pages compressed and you try to do the same through PHP using "ob_gzhandler", that warning appears at the very top of the page. Quote
