Php Problem
kaz
I dont get this. I have the following PHP code on my (home.php) page.
><?php
if ($bbuserinfo['userid']!=0) {
$username=$bbuserinfo['username'];
echo("
<table border='0' cellpadding='0' cellspacing='0' width='100%' >
 <tr>
   <td width='100%'><a href='forum/private.php?'>Private Messages</a> |
   <a href='forum/forumdisplay.php?f=128'>Forum Announcements</a> |
   <a href='forum/search.php?do=getnew'>New Posts</a> |
   <a href='forum/login.php?do=logout'>Logout</a></td>
 </tr>
 <tr>
   <td width='100%'><align='center'><span class='sectionheader'>Welcome back, $username!<br></td>
   </tr>
                       </table>
} else {
 <tr>
 </tr>
 <tr>
   <td width='100%'>Please login or click here to <a href='forum/register.php?'>register</a> for free
<form action='/forum/login.php' method='post' onsubmit='md5hash(vb_login_password,vb_login_md5password)'>
       <script type='text/javascript' src='/forum/clientscript/vbulletin_md5.js'></script>
        <span class='sectionheader'>Username:</span>
           <input type='text' class='button' name='vb_login_username' id='navbar_username' size='15' accesskey='u' tabindex='1' value='' onfocus='if (this.value == 'username') this.value = '';' /><br>
           <span class='sectionheader'>Password: </span>
           <input type='password' class='button' name='vb_login_password' size='15' accesskey='p' tabindex='2' /><br>
           <input type='checkbox' name='cookieuser' value='1' tabindex='3' id='cb_cookieuser_navbar' accesskey='c' checked='checked' /><span class='sectionheader'>Remember Me</span><br>
       <input name='submit' type='submit' class='button' accesskey='s' tabindex='4' title='Log In' value='Log In' />
       <input type='hidden' name='do' value='login' />
       <input type='hidden' name='forceredirect' value='1' />
       <input type='hidden' name='vb_login_md5password' />
       </form>
                       </span> </td>
                       </tr>
                       </table>
However this code appears to do nothing it just shows blank :eek:
The echo command just looks like:
echo "Hello world";
But on your page, it's set up as echo("Hello World"); (although with the two groups of HTML text).
So the parenthesis you have for it aren't needed.
Also, in the second part of the code after:
} else {
you don't have any sort of command, just a parenthesis and all the HTML text. You need to add an echo command in that half as well. It should look like:
<?php
echo "
[all your HTML text]
} else {
echo "
Hi that worked but I get a error this is the code i used
><?php
echo "
 <tr>
   <a href='forum/search.php?do=getnew'>New Posts</a><br>
   <a href='forum/login.php?do=logout'>Logout</a> Click <a href="/forum/?">here</a> to go to the forums or continue to browse at your ease
   </td>
 </tr>
 <tr>
   <td width='100%'></td>
   </tr>
                       </table>
} else {
echo "
 <tr>
   <td width='100%'>Welcome Guest, Please <a href='forum/register.php?'>register</a> for free
                 <span class='sectionheader'>Username:</span><br>
           <input type='text' class='button' name='vb_login_username' id='navbar_username' size='10' accesskey='u' tabindex='1' value='' onfocus='if (this.value == 'username') this.value = '';' /><br>
           <span class='sectionheader'>Password:</span><br>
           <input type='password' class='button' name='vb_login_password' size='10' accesskey='p' tabindex='2' /><br>
       </form>
                       </span> </td>
                       </tr>
                       </table>";
I get this error :whip:
Warning: Division by zero in /home/deathea/public_html/home.php on line 159
Warning: Division by zero in /home/deathea/public_html/home.php on line 167
The line 159 reads
Its right before the else command
I believe you're seeing that error because you have unescaped quotes in the echo() string:
The quotes in the second href attribute need to be escaped as \" (or replaced with single quotes as you have in the first href attribute):
>  <a href='forum/login.php?do=logout'>Logout</a> Click <a href=\"/forum/?\">here</a> to go to the forums or continue to browse at your ease
Kaz, another way to code this is to use
HEREDOC to print
preserving spaces and mixing html and both quotes and even php variables.
follow the echo or print tag with <<< and then a delimiter like HEREDOC
using
><?php
print <<< HERDOC
<tr>
</tr>
<tr>
  </tr>
</table>
HERDOC;
} else {
print <<< HEREDOC
<tr>
</tr>
<tr>
      </form>
                      </span> </td>
                      </tr>
                      </table>
HEREDOC;
The HEREDOC way is fine however in Dreamweaver, you just get the PHP icon in the WYSIWYG view which makes is less friendly to edit the html as you have to now use code view.
So I now do the following and it works very well.
<?PHP if(condition){ ?>
A BUNCH OF HTML GOES HERE WITH OR WITHOUT PHP EMBEDDED
<?PHP } ?>
Only if the condition is true will the html be rendered. You see all the HTML in Dreamweaver's WYSIWYG view so it is very easy to maintain.
Of course you can also replace
<?PHP } ?>
with
<?PHP } else { ?>
MORE HTML
<?PHP } ?>
AND SO ON
Wayne
