Cpanel
Getting this error on bottom of my control panel:
ERROR 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) ERROR 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) ERROR 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) ERROR 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Showing the same info on left panel SQL box, did i mess something up dont think i ever touched anything to do with SQL.
Guys -
If your going to leave posts that require help at least give me some room to work with here.
Server?
Domain?
Username?
I think your both on server21, which was rebooted due to it dropping connections right at around the time you posted this.
Please update this with more info.
Thanks
