Ftp
I have been experimenting with the my forums for few weeks by deleting and uploading many files. Most files are tiny gifs or php forum related in large numbers
During upload process, after few seconds the server would reject the connection.
Since i am only experimenting with my website right now, it involves lot of deleting. Even if i delete the (folder) files through FTP , it will stop responding
So this problem is not just upload related.
I always have to disconnect and reconnect and upload over and over again, but now i am tired of this, so i am asking for solution
I usually dont post and try to fix problems myself. I searched your forums and tried many different FTPs, Passive mode, ASCII mode yada yada it doesnt work!
Please help....
Edited by eflanker
thank you sir(s)
I am using TurboFTP
I have also tried FileZilla.
>STATUS:>	Socket connected (IP = 72.9.230.178), waiting for server response ...
220 ProFTPD 1.2.10 Server (ProFTPD) [72.9.230.178]
COMMAND:>	USER mplounge
331 Password required for mplounge.
COMMAND:>	PASS (not shown)
230 User mplounge logged in.
COMMAND:>	SYST
215 UNIX Type: L8
COMMAND:>	FEAT
211-Features:
 MDTM
 REST STREAM
 SIZE
211 End
STATUS:>	This site can resume broken downloads.
COMMAND:>	pwd
257 "/" is current directory.
COMMAND:>	TYPE A
STATUS:>	Data connection opened.
200 Type set to A
COMMAND:>	PASV
227 Entering Passive Mode (72,9,230,178,234,116).
COMMAND:>	LIST -la
150 Opening ASCII mode data connection for file list
STATUS:>	775 bytes received in 00:00:00 (4.025 Kbytes/sec)
STATUS:>	Resolving links...
COMMAND:>	CWD /www
226 Transfer complete.
250 CWD command successful
COMMAND:>	CWD /
COMMAND:>	REST 0
350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
COMMAND:>	NOOP
200 NOOP command successful
Welcome to the family and forums eflanker  :D
Are you on a dial-up?
reliable connection?
speed?
Winmodem (internal)?
I used to have similar problems with a winmodem and had to goto an external modem, what a difference.
Hi
I am on regular Cable connection
DUH- :wallbash: - it seems to work fine now byitself. Right after I posted my problem, it fixed by itself next day.
Before that I was having this problem ever since i joint TCH which was over a month ago.
I understand that the problem has nothign to do with your quality of service. Its a settings issue, either from client or server side.
FTP does freeze sometimes, but its more like 1 out of 10 times now under heavy load, which is fine with me. It was 10 out 10 times before.
So anyway I am busy building website right now.
Thanks for your great service.
Edited by eflanker
This is called Forumfix. Its only found at TCH Forum. It seems as soon as you take the time to write out the problem forumfix waves its magic wand and all is well.
Enjoy Forumfix :D
Weezy
Enjoy Forumfix :D
Weezy
WEEZY -
Can we please install wife-fix 2.0 ?
Thanks
Bill
