Php Help
kaz
Parse error: parse error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /home/deathea/public_html/khaleel/html/userarea.php on line 76
Line 76 Reads
><font face='Verdana' size='1'>Welcome Back <?php print $_SESSION['user'];
     // Print out admin links
     if($_SESSION['permission'] > 1){
     <a href = 'modUser.php'>mod user</a>|<a href = 'delUser.php'>del user</a>|<?php
     ?></font>
I need help with this, can anyone help me please?
I don't know about the error specifically, but right now the PHP has a second opening tag in the middle of it and the html within the brackets isn't set up to actually do anything--the PHP engine is trying to render it as PHP and not HTML, I think. Which could be enough to trigger that error.
Try:
if ($_SESSION['permission'] > 1) {
echo "<a href='modUser.php'>mod user</a>|<a href='delUser.php'>del user</a>";
</font>
One word of warning--the way it's set right now, it would be possible for someone to randomly set up a permission value of, say 1000, and it would print out this bit of menu. If you know the actual permission values of your admin users, it would be better to set up something like
>if ($_SESSION'permission'] == (1|2|3)) {
I'm not certain that's the exact syntax, but something like that would be more secure--look for an exact permissions match, instead of "any number greater than 1."
In your original code, you just missed the first closing PHP tag (right before the HTML string):
    ?></font>
Did not fix all of the code, problem was example
><?php
echo'<a href="page.asp?go=shop">Go the shop</a>';
// as you can see, the quotes are " and should be '
It should be
><?php
echo"<a href='Page.aspx?Go=Shop'>Go the shop</a>";
// quotes are fine and work they should be '
Done :) thanks all anyways
Actually, Kaz, changing the quotes from " to ' in your HTML is not correct, although it will work on many or perhaps most web browsers.
What you want to do is type in /" when you are typing a string to be output to the browser and need to have a quote. The backslash is the "escape code" -- it tells PHP "No, this isn't the end of my string; I want to put an ACTUAL quote mark INSIDE the string, please!"
><?php
echo "<a href=\"Page.aspx?Go=Shop\">Go the shop</a>";
See this link for more complete info on how to format PHP strings: PHP Manual page on string data
