Make Posted February 28, 2005 Posted February 28, 2005 It seems to be strange but .htaccess is uploaded correct and i can not see him through CuteFTP as another files!? Everytime if i would to download him or performance CHMOD i need to go through Cpanel. It is strange.Can someone answer me on this qeustion. THanks Quote
TCH-Thomas Posted February 28, 2005 Posted February 28, 2005 Hi, I don´t use cuteftp, so I can´t help you specifically with that program but the .htaccess are usually set to be a hidden file when trying to view it through a ftp program. I had the same problem with my ftp program. Please have a look in your ftp´s help file how to change so you can see it. Quote
Make Posted February 28, 2005 Author Posted February 28, 2005 Thanks for reply but it does not hae anything to do with cuteftp. I use cuteftp last 4 years and on my previosly 3 hosting .htaccess was always visible. I think it is from server side. Quote
TCH-Tim Posted February 28, 2005 Posted February 28, 2005 Thanks for reply but it does not hae anything to do with cuteftp.I use cuteftp last 4 years and on my previosly 3 hosting .htaccess was always visible. I think it is from server side. <{POST_SNAPBACK}> I use CuteFTP and used to be able to see my htaccess files. But I just checked and I don't see them anymore. Weird. Quote
Make Posted February 28, 2005 Author Posted February 28, 2005 It seems that it is then something from server side! Hoepfully will be fixed soon! Quote
TweezerMan Posted February 28, 2005 Posted February 28, 2005 TCH's servers run on a Linux operating system, and on Linux, any file name that starts with a "." is a hidden file. It is not a server problem - it is the way the Linux OS identifies hidden files. (Linux does not have a special hidden file attribute like there is on Windows systems.) If your FTP program is not configured to show all files (including hidden ones), then you will not see files with names that start with a "." like ".htaccess". To find out how to display hidden files in CuteFTP, I did a quick search on Google for cuteftp "hidden files", and these instructions turn up on a number of pages: You can set up CuteFTP to display these hidden files as follows: Open up the Edit menu and select the Filter option. Check the box next to Enable Remote Filters. Enter the two characters "-a" (without the quotes) in the Remote Filter box. Click OK to confirm the change. The next time you make an FTP connection to your account, you should be able to see the hidden files which were not visible before. (Note: The "-a" tells the FTP server to "Show All Files", which will include hidden files in any file list displayed by the FTP server.) Quote
Make Posted February 28, 2005 Author Posted February 28, 2005 Thanks.After following your instruction .htaccess become visible again! Quote
raxit4u2 Posted January 29, 2010 Posted January 29, 2010 Here i found the solution for making htaccess visible in CuteFTP and filezilla as well. Thanks. Quote
TCH-Thomas Posted January 29, 2010 Posted January 29, 2010 Welcome to the forum, raxit4u2. I have removed the link in your post due to the following forum guideline Family Members (or others) may not use the Forum for advertising or to drive traffic to their site. Also, do you realize that this thread is nearly 5 years old? Quote
