Mt 3.15
chroniker
:goof: I'm following the instructions found here - totalchoicehosting.com/help/id76.htm
After a couple of reinstalls and messing with permissions I am able to progress to Step 5 "Run MT-Load Utility". When I do, I get -
Bad ObjectDriver config: Connection error: Access denied for user: '@localhost' (Using password: YES).
Obviously I used a stronger pw when setting up the MySQL db, I have added a user and I have put the pw in mt-db-pass.cgi
Also, I have checked my errorlog and found -
Premature end of script headers: /home/demesne/public_html/mt/mt-load.cgi
and
Premature end of script headers: /home/demesne/public_html/mt/mt-check.cgi
Anybody here have any ideas on what I'm doing wrong?
By the way, being a newb, I was not aware that cgi's are exicutable and after reading where six apart says to set permissions to 755 on all cgi's I was able to make it to step 5. You may want to see about including this in your install instructions.
In your mt.cfg change
>Database <cpanelname_dbname>
DBUser <cpanelname_user>
To
>Database cpanelname_dbname
DBUser cpanelname_user
And uncomment the following lines.
DBUmask 0022
HTMLUmask 0022
UploadUmask 0022
DirUmask 0022
:D ;) ;) :)
My thaks to TCH-Dick and the author of MT-Medic.
A
I have told it to rebuild all files several times.
Did you configure the weblog? Instructions for that are at
http://www.movabletype.org/docs/mtmanual_w...fig.html#weblog configuration
Usually the first things I do are:
1. Install the software
2. Login using the default Melody/Nelson login
3. Go change Melody/Nelson to what I want my username and password to be, via "Edit Your Profile"
4. Go to "Config Weblog" under the default blog "First Weblog"
5. Adjust the blog name to what I want and the paths to where I want the blog to show up
6. Set my local time
7. Click save at the bottom
8. Go to Preferences
9. Choose my preferences - default language, whether I'll allow comments or trackbacks, etc.
10. Click save at the bottom
11. Go to Archiving
12. Add Category archiving and make sure the box is checked
13. Click save at the bottom
14. Rebuild the blog using the "Rebuild Site" button on the lower left menu.
And the blog (albeit empty) shows up. Did you do all those things?
-Iki
I uploaded to the server before unpacking the tarball and made all of my config changes there. When I was finaly able to run mt-check.cgi and mt-load.cgi, everything showed good to go.
I did the 14 steps you mentioned but when I rebuild I return to my admin main page and when I view my site all I get is my index page and I have cleared my cache on the 3 pc that I have access to at two different physical locations.
It's not your PC.
Your blog isn't in your root directory, that's why you can't see it. It's publishing to a directory called "mt". That's the software's default behavior; you didn't change the weblog configuration to put it in the root directory. That'd be step 5. :)
Also, it shows up with no style because in your index template you're saying the stylesheet is located in your root directory, and it's not - it's probably also located under the "mt" directory because you didn't change the configuration.
-Iki
