....best Way To Get Mp3 Files Indexed
boxturt
Do mp3 files even get indexed by search engines on their own? If so, are they indexed as stand alone files or is an accompanying text file required such as a m3u playlist?
And yes, before anyone asks, royalties, copyrights and performance rights are not an issue.
As always, thanks.
Thanks. Apparently they do get indexed but it would appear that the links indexed are from the media player (WimpyPlayer) or the folder index.
For instance if I search for s03_Regina_Coelis_(e).mp3 with google you get ...
www.naugatuckarts.org/choir_mp3/index.php?SortBy=1&fdir=./ 2%20Spring%202003%20Vienna%20in%20Spring/
which is only a link to the folder it's in , not the mp3 itself. ... That would be ...
http://naugatuckarts.org/choir_mp3/013%20S...202003%20Vienna
%20in%20Spring/s03_Regina_Coelis_(e).mp3
Sooooooo, I guess that it does indeed need the text link. :)
