One Subdomain Sparadically Not Working
Zach
On my site I have two subdomains, blog.zachrosing.com and photo.zachrosing.com. The photo one sparadically stops working...I get a cannot find server error when I go to it. My main page and the blog one, however, work perfectly fine. I've had other people tell me they have the same problem.
I just tried it, and i'm still having this problem. It wasn't working when I tried it last night (around 1am).
Any ideas?
zach
No.
I can't even get it to start. It says "unable to resolve target system name photo.zachrosing.com".
Can anyone out there access this site? Is anyone having problems getting it to come up?
zach
I'm having the same problem. My photos.twowheels.us subdomain doesn't work sometimes. A friend had the same problem (he is also on server16) a few days ago. I tried going to his subdomain, and kept getting "Could not locate remote server", which later he mentioned to me that he was having the same problem.
I set up all of my pages to point to a subdomain so that if I move files around links to them will still work... now nobody can get to my photos, but it'd work fine if I wasn't using subdomains!!! :D :(
Same result as Zach. Unable to resolve target system name.
I guess I don't see how it cannot be a TCH problem. I could understand if only 1 or 2 people couldn't see it. But it's been days now and this is still happening and friends from across the country, all using different ISPs cannot see it - or at least periodically cannot see it. Especially since I'm obviously not the only one having this problem.
Ok slow down Mr. Adventureran.
I just tried your subdomain from three connections, ran tracerts from three connections and they are all locating and displaying your subdomain just fine.
Here are the results of my testing. Afterwards I come to the conclusion that this is NOT on our end.
Server: DNS server ns4.coastlandtech.com
aaron.ransplace.com internet address = 66.246.85.77
ransplace.com nameserver = ns1.totalchoicehosting.com
ransplace.com nameserver = ns2.totalchoicehosting.com
ns1.totalchoicehosting.com internet address = 64.246.50.105
ns2.totalchoicehosting.com internet address = 65.254.32.122
Non-authoritative answer:
ransplace.com
origin = ns1.totalchoicehosting.com
serial = 1051321856
refresh = 28800 (8H)
retry = 7200 (2H)
expire = 3600000 (5w6d16h)
minimum ttl = 86400 (1D)
Authoritative answers can be found from:
Also - I ran digs on your subdomain and they were all fine.
The only thing I see that you have done wrong, is when your account was upgraded to reseller you didnt change the Nameservers. This might effect this issue, but I doubt it.
You should update your Nameservers to
NS1.TOTALCHOICEHOSTING.COM and NS2.TOTALCHOICEHOSTING.COM
Further please provide more detailed information. It helps me trace down problems.
I posted at 11:07am that it is working and it is now 12:20pm and it is still working.
If the subdomain will work for some and not others, it eliminates TCH as the problem. Do a tracert to the subdomain and see where it's getting dropped.
Lianna hits it right on the money.
If one user can see it but not another how can you assume its our server.
Our server is either working or its not.
This sounds like one of two things.
Routing Issue
Lame DNS lookups on the ISP end.
ns1.totalchoicehosting.com internet address = 66.11.162.138
ns2.totalchoicehosting.com internet address = 209.51.158.250
ransplace.com
serial = 1051321856
retry = 7200 (2H)
Whatever. Ok, so no subdomains will work for me through your servers, however, with other hosts it's no problem.
And, I never upgraded to a reseller account. I purchased one from the start and used the information given to me at that time for my nameservers. If they were wrong, then I was provided with incorrect information.
  • 2 months later...
i am having the same problems with certain subdomains on my site. i have several:
blake.exudate.net (my main page)
faq.exudate.net (my faq)
gallery.exudate.net (my photo gallery)
guests.exudate.net (my guestbook)
i have never once had a problem with the 'blake' or 'faq' subdomain, but i have very little luck with 'gallery' and 'guests' from home (the folders DO work when not using the subdomains). when i try from work, it works perfectly fine every time. i used the DNS Lookup Utility i saw mentioned and all seemed fine. the problem only started recently with the subdomains not working right - only very seldom do the 'gallery' and 'guests' subdomains work (usually late at night) but ONLY from my HOME do i have this problem.
the error message i get is:
Gateway Timeout
The following error occurred:
A gateway timeout occurred. The server is unreachable. Retry the request. (GATEWAY_TIMEOUT)
you can understand my frustration, i'm sure.
i understand that the subdomains are working on the TCH end and that it is my isp's problem (shaw.ca broadband) but getting any sort of answer from them is an exercise in frustration on a regular basis. what would you suggest i could do to remedy this problem? i'm willing to communicate with my isp to resolve it, i just have no idea what to approach them with - do you know what i mean? i figure if you could give me some tips on what information i (or they) require they may be inclined to help me rather than insult me and tell me that i'm probably spelling the url wrong.
any help would be greatly appreciated.
thank you.
i'm sorry, i forgot two other subdomains:
mt.exudate.net (movabletype)
mail.exudate.net (squirrelmail webmail)
the 'mt' subdomain always works, even from home, while the 'mail' subdomain (which i use for access to my email from work, as they do not allow access to the port specified over the corporate network for the webmail you have installed) does not work from home (it works fine from work, as with the 'gallery' and 'guests' subdomains in my last post).
as i said in my post, it's only inaccessable from my home - otherwise it seems to work correctly (even from my place of work) i just don't understand how to get the subdomains back up and working from my home...they worked perfectly fine up until about three weeks ago.
what could my isp do to prevent me from being able to access my subdomains - and only certain ones at that? :rolleyes:
  • 1 year later...
HI- I am having a very similar problem to what was discussed here re: MT
I have an account on server 77 username wwwcon.
I have registered a domain that has in fact propagated: www.blueplanetdivers.org.
MT is installed at home/wwwcon/public_html/mt
I log into mt thru www.conservancydivers.org
I created new blog using www.blueplanetdivers.org in my pathway config
When i try to rebuild, i get a "could not locate remote server" msg. Nor can I rebuild.
I have a hunch that I am messed up with my blog config, but not sure how.
As usual, any and all help much appreciated!
Cheers-
Dida
:unsure:
That's right-the mt folder is on conservancydivers.org . I do not want to do a second install. Isn't this how MT should work-that I can create multiple blogs with diff URLS on one install? (fyi- have reseller account)
Just when I think I'm getting the *teensiest* grip on understanding MT, I'm thown off course again!
whee! ;)
Dida
