Php/mysql Script Question
!!blue
I've created a database of links with URIs, titles, and descriptions. It is uploaded safely to my website via phpMyAdmin.
So I want to have a php page show the database similar to this hard-coded page on my blog (I'm making a replacement):
http*//blog.zoblue.com/link-list.php
I followed some tutorials online, and after some tweaking, it shows the page like this:
http*//zoblue.com/connect.php
Here's the PHP code that outputs the above:
><?php
/* connection info taken out here*/
echo 'connected successfully' . "<br /><br />\n";
$query="SELECT * FROM linklist ORDER BY 2, 4;";
$result=mysql_query($query);
$num=mysql_numrows($result);
mysql_close($link);
echo "<strong>Database Output</strong>\n<br />\n";
$i=0;
while ($i < $num) {
$type=mysql_result($result,$i,"type");
$name=mysql_result($result,$i,"name");
$url=mysql_result($result,$i,"url");
$desc=mysql_result($result,$i,"desc");
echo "<strong>" . $type . "</strong>\n";
echo "<dl><dt><a href='" . $url . "' title='" . $name. "'>" . $name . "</a></dt>\n";
echo "<dd>" . $desc . "</dd></dl>\n\n";
$i++;
echo "\n<br><br>\n";
but I'd like to group the links by their category (the type column in the DB table). Can anyone help me do this? I can't wait for my PHP and MySQL books to come in the mail; young grasshopper has no patience. ;)
thanks,
!!blue
Ooop! I forgot that:
key | type | name | url | desc
key = number; auto increment unique id
type = text; the type of link, e.g. 'css sources', 'entertainment', 'music'
name = text; usually the title of the page
url = text; the actual URL of the link
desc = text; a short one or two sentence description of the link
Hi Blue
Ok now that I have that information I have just a few questions for you
the links that you posted
//blog.zoblue.com/link-list.php hard coded code
and then
//zoblue.com/connect.php Actual PHP generated code
the links displayed on your hardcoded page reflect the following markup EXAMPLE
><b>Daily Links: </b>
<ul>
<li><a href="http://www.hotmail.com" class="link" target="_blank">Hotmail email</a></li>
<li><a href="http://mail.yahoo.com" class="link" target="_blank">Yahoo email</a></li>
</ul>
the new PHP generated creates markup as such
><strong>career</strong>
<dl><dt><a href='http://www.cityofchicago.org/mowd' title='Chicago Office of Workforce Dev'>Chicago Office of Workforce Dev</a></dt>
<dd>helps Chicagoans find and train for jobs; help businesses find workers</dd></dl>
<dl><dt><a href='http://chicagobusiness.com/' title='Crain's Chicago Business'>Crain's Chicago Business</a></dt>
<dd>Chicago business news, lists, rankings, directory and more</dd></dl>
The difference between them is in your hardcoded example you are using
  • within an unordered list element
    and the php is generating a definition list
    and a definition description
    To change the php to print out the URLs in like you have on your hardcoded page
    you will need to change it to look like this
    mysql_close($link);
    echo "<ul>\n";
    $i=0;
    while ($i < $num) {
    echo "<li><a href='" . $url . "' title='" . $name. "'>" . $name . "</a></li>\n";
    $i++;
    echo "</ul>\n";
    If this is not what you were looking for let me know
    take care
    Robert
    I do want a definition list so that each link has a short description. But the PHP script I'm using loops through the links and spits out each DB table row like this:
    >career
    career
    career
    Creative Directory
       resource for the creative community in the Midwest
    but I want the table rows to be shown like this, grouped together by type:
    >career
    Creative Directory
    sorry, I didn't explain visually ;)
    thanks,
    !!blue
    Hi Blue ,
    Ok I dont have a way to test this but I think this is basically what you are after
    What I did was add an additional while statement to check that if the type has changed
    try this and let me know if you get any errors
    *** Edit *** might need to move the inital holdtype above the code
    while ($i
    ><?php
    mysql_close($link);
    $i=0;
    while ($i < $num)
    $holdtype=$type;
    echo "<strong>" . $type . "</strong>\n"; /* initialize First Type */
      while ($holdtype = $type)
    	 $i++;
    $holdtype = $type;
    	 $i++;
    eek! that gave me this:
    >career
    kinda scary, I had to stop the page from continuing to load. ;)
    Hi Blue I did not get an answer from other board that helped much but I did finally figure it out
    >       echo "connected successfully\n";
    $query=mysql_query("select * from bluetest group by type");
    while($row=mysql_fetch_assoc($query))
    $cat=$row['type'];
     if($cat!=$lastCat)
     echo "<strong>" . $cat . "</strong>\n";     	 //output Catagory type
     $lastCat=$cat;  //set lsat type to current type
    //do the rest of outputing articles
    //second query to retrieve the actual URLs
        $query2 = "SELECT namel,url,descrip FROM bluetest WHERE type='$cat'";
        $result2 = mysql_query($query2) or die(mysql_error());
        while ($row2 =  mysql_fetch_array($result2))
        echo "<dl><dt><a href='" . $row2["url"] . "' title='" . $row2["namel"] . "'>" . $row2["namel"] . "</a></dt>\n";
        echo "<dd>" . $row2["descrip"] . "</dd></dl>\n\n";
    you will need to tweek it a little bit but it does work
    here is my output
    <br />
    <dl><dt><a href='http://www.salary.com/hom' title='Salary'>Salary</a></dt>
    <dd>providing employee compen</dd></dl>
    <dl><dt><a href='http://www.techies.com' title='Techies'>Techies</a></dt>
    <dd>job search; company resea</dd></dl>
    <strong>cars</strong>
    <dl><dt><a href='http://www.kbb.com/' title='KBB'>KBB</a></dt>
    <dd>Kelley Blue Book; search</dd></dl>
    <strong>code sources</strong>
    <dl><dt><a href='http://www.actionscript.o' title='Actionscript links'>Actionscript links</a></dt>
    <dd>forum entry with motherlo</dd></dl>
    <dl><dt><a href='http://www.blooberry.com/' title='Blooberry HTML'>Blooberry HTML</a></dt>
    <dd>None</dd></dl>
    If this does not work please feel free to message me
    Good luck
    Robert
