Mysql/php/web
Spitsbe
I too am having problems getting my data bases on my web.
I fear that it is something simple like a file in the wrong place or something. I have made a php file, "30.php" and used the file download link (via cute) to link it to my Site.
I also am not connecting to the db.
Here is the code that I am attempting to use. If any one once to take a stab at it. I sure could use some help. I been at this for a couple of days.
<html>
<head>
<title>Over 30 league</title>
</head>
<body>
<?php
$dbcnx = @mysql_connect('localhost', 'public_html', 'passswd');
if (!$dbcnx) {
die( '<p>Unable to connect to the '.
'database at this time.</p>' );
if (! @mysql_select_db('spitsyc_Over') ) {
die( '<p>Unable to locate the data tb.</p>' );
<p> teams: </p>
<blockquote>
<?php
$result = @mysql_query('SELECT TeamText FROM Over 30 teams');
if (!$result) {
die('</p> Error performin query: ' . mysql_error() .
'</p>');
//While ( $row = mysql_fetch_array($result) ) {
// echo('<p>' . $row['TeamText'] . '</p>;
I took out the last part to try and simplify.
Thanks in advance, Spitsbe
Well, I think I got it talking to the DB now. I am pretty sure that it sees my sql too. Now I just need to get it to display it on my Web page.
I took out the @ error suppresion operators so I could see the errors that were coming up. Thus, I have cleared the errors.
Now I am getting a
Parse error: parse error, unexpected $ in /home/spitsyc/public_html/HTMLobj-232/30.php on line 37
Step by step. it wont be long now.
Spitsbe
This is where I am now. I found the line 37 error. I working on the line 32 error now. lol
Parse error: parse error, unexpected ';' in /home/spitsyc/public_html/HTMLobj-240/30.php on line 32
<html>
<head>
</head>
<body>
<?php
$dbcnx = mysql_connect('localhost', 'spitsyc', 'passwrd');
if (!$dbcnx) {
<p> teams: </p>
<blockquote>
<?php
$result = mysql_query('SELECT * FROM `Teams` WHERE 1');
if (!$result) {
die('<p>Error performing query: ' . mysql_error() .
'</p>');
echo('<p>' . $row['Teamsx'] . '</p>'; <---line 32
</blockquote>
</body>
</html>
Thanks for jumping in. I can taste victory on this.
Amazing, I got it to work.
The biggest help was taking the error supression off.
In addition I found a couple of typos. And the what do you know.
Thanks for your help.
Now it's on to other battles.
I hope I didn't waste too much of anyones time. I can't believe I have been messing with this for 2 days. lol
Spitsbe
