tmccartney66 Posted December 16, 2004 Share Posted December 16, 2004 I've installed Advanced Guestbook and have it running at http://www.amysedaris.com/guestbook . I don't like the little "Thank you for stopping by my site. Here you can leave your mark" thing at the top of the page, but I've searched through all the templates and php and can't find it to get rid of it. Does anyone know where it is? Also, when I get into the template editing form, a little red message tells me to "Give write permissions to the webserver on the template files!" So when chmodding those files, is the "webserver" the owner, group or public? In other words, what should my permissions be? Thanks, Tracey P.S. By the way, e-mail notification of replies doesn't seem to work. Any ideas? Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted December 16, 2004 Share Posted December 16, 2004 The permissions need to be 777 while you are making changes using the admin page. I downloaded the whole guestbook folder and use a text editor and ftp to make changes so I don't have to remember to put the permiossions back. As to the message see this post Quote Link to comment Share on other sites More sharing options...
tmccartney66 Posted December 17, 2004 Author Share Posted December 17, 2004 Just what I needed, Don - thanks! Tracey Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted December 17, 2004 Share Posted December 17, 2004 You are welcome Quote Link to comment Share on other sites More sharing options...
icode Posted March 6, 2005 Share Posted March 6, 2005 I have similar problem with permissions. I CHMODED the whole templates directory to 777 but if I try to make a change to a template I get the following messages: Warning: fopen(./templates/admin_enter.php): failed to open stream: Permission denied in /home/sweeps/public_html/guestbook/lib/admin.class.php on line 193 Warning: fwrite(): supplied argument is not a valid stream resource in /home/sweeps/public_html/guestbook/lib/admin.class.php on line 194 Warning: fclose(): supplied argument is not a valid stream resource in /home/sweeps/public_html/guestbook/lib/admin.class.php on line 200 I chmoded using my FTP client. Should I do it some other way? Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted March 6, 2005 Share Posted March 6, 2005 I think you need to change the permissions for the template file itself not the folder. When editing you should see the filename the guestbook is trying to change near the top. Quote Link to comment Share on other sites More sharing options...
icode Posted March 6, 2005 Share Posted March 6, 2005 I think you need to change the permissions for the template file itself not the folder.When editing you should see the filename the guestbook is trying to change near the top. <{POST_SNAPBACK}> Thank you. That worked. Now my next question is I want to replace the graphic that says "Guestbook". Do you know how to replace that (which template)? Thanks again! Quote Link to comment Share on other sites More sharing options...
Guest Serpentine Posted March 6, 2005 Share Posted March 6, 2005 It is in /templates/body.php It is called gbook.gif. You can either change it to what you want or call yours gbook.gif and overwrite it in the /img folder. Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted March 6, 2005 Share Posted March 6, 2005 Welcome to the forums, icode. Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted March 6, 2005 Share Posted March 6, 2005 Welcome to the forums icode Quote Link to comment Share on other sites More sharing options...
icode Posted March 7, 2005 Share Posted March 7, 2005 Welcome to the forums icode <{POST_SNAPBACK}> Thank you guys for the welcome. Hopefully I won't be a pest but I do appreciate your quick help. Quote Link to comment Share on other sites More sharing options...
borfast Posted March 7, 2005 Share Posted March 7, 2005 Welcome to the forums, icode Quote Link to comment Share on other sites More sharing options...
stevevan Posted March 7, 2005 Share Posted March 7, 2005 Welcome icode. Don't worry about asking questions...that's how we learn! We're like one big "family" here and there's always someone who has the answer! Quote Link to comment Share on other sites More sharing options...
carbonize Posted March 19, 2005 Share Posted March 19, 2005 I've installed Advanced Guestbook and have it running at http://www.amysedaris.com/guestbook . I don't like the little "Thank you for stopping by my site. Here you can leave your mark" thing at the top of the page, but I've searched through all the templates and php and can't find it to get rid of it. Does anyone know where it is? <{POST_SNAPBACK}> Advanced Guestbook is designed to be user friendly. It's so friendly in fact that 99% of the text you see is stored in the language file you are using, in your case english.php. This is found in the lang directory/folder. Quote Link to comment Share on other sites More sharing options...
