Subdomain Images Path?
Pocketman38
I have seen a few related posts relative to this subject, yet I still do not understand how to get a page in a subdomain to find images. For that matter, I assume links will be an issue as well.
cook.inssar.org was created with cPanel
http://cook.inssar.org/index.htm has images which are not displayed
I have tried putting the images in the root cook folder
<IMG SRC="image01.gif">
I have tried putting them in a folder cook/objects
<IMG SRC="objects/image01.gif">
I have tried accessing images in the main domain's objects folder.
<IMG SRC="../objects/image01.gif"> AND
<IMG SRC="http://www.inssar.org/html_public/objects/ind_flag.gif">
I assume there is a simple explanation. Suggestions please?
If its stored in the same directory(cook) it would be
><img src="images/myimage.jpg" />
If its outside of the directory(public_html) it would be
><img src="http://www.domain.com/images/myimage.jpg" />
or
><img src="/home/public_html/username/images/myimage.jpg" />
Gentlemen:
I have tried all the suggestions in Dick's reply and, still nothing.
<img src="/home/public_html/cook/objects/const.gif">
<img src="http://www.inssar.org/objects/const.gif">
<img src="/home/public_html/cook/objects/ind_flag.gif">
<img src="/home/public_html/objects/ind_flag.gif">
<img src "objects/ind_flag.gif">
<img src "../objects/ind_flag.gif">
I have all the images in both objects folders, and the cook.inssar.org root folder.
I dropped the subdomain and recreated. Still no success.
I noticed in Don's examples, "/" at the end of the tag
I even tried that.
Any other suggestions?
Where are the images?
in the same folder that represents the subdomain?
remember the subdomain is a shortcut to domain/folder
If in the same folder as your pages
<img src="myimage.jpg" /> will work
other wise the absolute url
<img src="http://www.domain.com/foldername/myimage.jpg" />
will also work.
edit-------
I see you are using relative addressing
<img src="../objects/ind_flag.gif">
try the absolute address
<img src="http://www.inssar.org/objects/ind_flag.gif">
when using in a subdomain
Edited by TCH-Don
This should work:
><img src="http://cook.inssar.org/objects/ind_flag.gif" />
but doesn't because it gives a 404 error while trying to find the missing 403 error page. So, you need to add that subdomain (http://cook.inssar.org/ and http://www.cook.inssar.org/) to your allowed sites in hotlink protection.
Don,
All good suggestions, but nothing works.
Properties (right click on image spot) says:
http://cook.inssar.org/objects/const.gif
Absolute path says:
I have even set up a second subdomain indy.inssar.org and get the same results.
I appreciate your efforts, but sadly, nothing works :)
Hotlinks protection was in fact turned on. I have added the subdomain to the allow list, and "all is well." :D
Prior to changing the hotlinks allow access list, I created a test subdomain on another website, copied the images and html, and it worked, even though the newly created subdomain was (is) not on the allow list ? :)
I still do not know why one site behaved differently than the other, but it's all working now and I've learned from the experience.
Thank you all for your perseverance.
