Direct Link To Horde?
25PSi
Hi all.
Anyone has any idea on how to make a DIRECT link to Horde email client? I do not want to log in and choose one of the 3, I want to be able to go straight to HORDE. I like it best.
Perhaps some call script or something.
Can anyone help, please.
Thanks in advance.
Eugene
http://www.domain.com:2095/horde/index.php is not what i am trying to get.
If you follow that link it'll pop a window and will ask you to log in, then you can choose one of 3 email clients.
I would like to put link DIRECTLY to Horde on my site. So you can click link and be taken to Horde login interface.
Am i explaning it well?
Eugene
I can be wrong but I dont think that it is possible with another way than this. Sorry.
Edit: I read your reply once more which says:
In my case the standard windows login box shows up yes, but then I am directly directed to horde without having access to neomail or squirrelmail.
Edited by TCH-Thomas
I use both IE and Netscape 7.0. It works in both for me. As I said above I initially bookmarked my Horde Inbox... this is the URL that pops up when I click on the bookmark so I figured 25PSi could create a direct link from it.
Thanks... where was I again? :)
By the way.... I like the bookmark better than a link from my site because with the bookmark I can get to it from any site I happen to be on. Most of the time I'm on this forum site so a link from my own site would be an extra step. So long as my browser is open I can go straight to Horde using the bookmark (or favorites as they're called in IE).
Straight to Horde... hmmmmmmm, sounds like somewhere more than a few people would like to send me! :)
Actually you dont have to do anything but upload the files. You rename anywhere.php to whatever you want and just use it or include it in a page.
I looked at it again though and this isn't going to work either. I'll see if it can be modified to fit your needs or find a better route.
  • 2 weeks later...
Try a link like this: http://******:2082/horde/index.php
That link works for me. Waht browser are you using?
Welcome home by the way.
Hi Rob,
I am also trying to use Horde as my prefer webmail client and tried your link but it guides me to CPANEL instead of logging into Horde mail. I use IE and Firefox. Both with same result..
-Dave
Ok...never mind, the link should be http://****:2095/horde/index.php, not
http://****:2082/horde/index.php
Also, is it possible to eliminate the second login? Once the IE login comes up and I entered my information, Horde mail asked me to login again. However, all I really needed to do is click login b/c the rest of the login information has been filled in for me. But I still think having to click LOGIN the second is unnecessary. Anyone knows how to eliminate this second step?
-Thx.
-Thx.
Why don't you install Horde yourself to your own account? Then you can completely control exactly how it works!!! :clapping: :yes:
  • 2 months later...
