puneetworld Posted October 15, 2004 Share Posted October 15, 2004 Actually i have recently bought this directory script which has this security feature which enables person to type in the number or alphabets so that the directory cannot abused by using bot or any other thing.. i am try to enable it but it isnt working i tired GD but it doesnt might be GD is not installed.... i checked image magic is installed so can you tell me what is the path to image magic on TCH server and ... so that i can try again ... and if still it doesnt work then ill have to contact the script author for support. Quote Link to comment Share on other sites More sharing options...
LisaJill Posted October 15, 2004 Share Posted October 15, 2004 GD is fully installed. =) The ImageMagick path is: /usr/local/bin Quote Link to comment Share on other sites More sharing options...
puneetworld Posted October 15, 2004 Author Share Posted October 15, 2004 i tried that but it didn't work i think there this issue with this server only... because one of my friend using the same script he also uses.. TCH on his server its running properly... well when i try to run this script which a part of security in the directory suppose to display random security image THe script attached Below the Error i get br /><b>Fatal error</b>: imagepng(): gd-png: fatal libpng error: Incompatible libpng version in application and library i think this because two conflicting version installed.. not compatiable.... could you please look into this Thanks -puneet securityimage.php Quote Link to comment Share on other sites More sharing options...
TCH-Dick Posted October 15, 2004 Share Posted October 15, 2004 you need to open a help desk ticket in order for a tech to look into it. Quote Link to comment Share on other sites More sharing options...
