Awstats On Frontend
Rajio
does anybody know anything about this?
http://www.telartis.nl/xcms/awstats
looking for a way to display stats on the frontend. this looks good actually, (judging by the demo)
tried installing the php file. but dont know what to put for the settings:
* SETUP SECTION
* Set this value to the directory where AWStats
* saves its database and working files into.
$DirData = "/var/lib/awstats";
* The URL of the AWStats script.
$AWStatsURL = "/cgi-bin/awstats.pl";
* Set your language.
* Possible value:
*  Albanian=al, Bosnian=ba, Bulgarian=bg, Catalan=ca,
*  Chinese (Taiwan)=tw, Chinese (Simpliefied)=cn, Czech=cz, Danish=dk,
*  Dutch=nl, English=en, Estonian=et, Euskara=eu, Finnish=fi,
*  French=fr, Galician=gl, German=de, Greek=gr, Hebrew=he, Hungarian=hu,
*  Icelandic=is, Indonesian=id, Italian=it, Japanese=jp, Korean=kr,
*  Latvian=lv, Norwegian (Nynorsk)=nn, Norwegian (Bokmal)=nb, Polish=pl,
*  Portuguese=pt, Portuguese (Brazilian)=br, Romanian=ro, Russian=ru,
*  Serbian=sr, Slovak=sk,  Spanish=es, Swedish=se, Turkish=tr, Ukrainian=ua,
*  Welsh=wlk.
$Lang = "en";
* Set the location of language files.
$DirLang = "/usr/share/awstats/lang";
* Config names to filter. Shows all if empty array.
$FilterConfigs = array();
To read website configs from database, do something like:
$sql = "SELECT config FROM users WHERE (user=...)";
$rs = mysql_query($sql); if ($rs) while ($row = mysql_fetch_array($rs)) $FilterConfigs[] = $row["config"];
if i run as is i get: Could not open directory /var/lib/awstats
>$DirData = "/home/cpanel_username/tmp/awstats";
$AWStatsURL = "http://www.******:2082/awstats.pl";
$DirLang = "/usr/local/cpanel/3rdparty/share/awstats/lang";
But this script looks like it doesn't take into account that the cPanel inatall of AwStats requires a password.
And out of curiosity why do you want to make your stats public?
thanks dick i'll try that out.
Reason i want to fiddle with showing the stats with this is that I want to be able to incorporate the stats into my site so that on a page that only my blog contributors can access (i'm using mambo btw) i can throw on some stats like unique hits per day / week / month, and latest refering URLs, but have that integrated into the website template ratehr than a page that looks totaly different (ie all white). since awstats is already installed and collecting this info i figured if i could port over some of that info into a "publicly available" page (ie without backend access) which i could customize into my site to be seamless, it'd be just what the doctor ordered.
I've tried to get this script working without success, all I get is "Could not open directory /home/syqbsbxa/tmp/awstats" which sounds like its cause it need a password like Dick said.
But it would be great if it was possible to get it working, cause then I could view the main stats of all of my accounts on the same page and compare them. Will it take much work to make it take a password?
James
  • 1 month later...
James
for it to work take out the
"cpanel_";
"cpanel_"; and then just fill the correct information where it says username and password.
"cpanel_";
You are looking at the wrong script, the one you reference (Awstats Access) has no problems. I have removed the underscore from "cpanel_username" to prevent any future confusion.
The script they had an issue with is from the first post in this thread
That script is for a standalone install of AWstats and does not contain the proper directories or credentials to access AWstats via cPanel.
