charle97 Posted May 8, 2006 Share Posted May 8, 2006 i'd like to try out typo, which requires ruby on rails. i saw the announcement about ruby on rails coming, but i don't know if we have it yet. if not, i can wait. assuming ruby on rails is installed, would typo be able to run here at tch? here are the requirements: Currently you need all of those things to get typo to run: * Ruby -v of 1.8.2 (25-05-2004) or higher. Ruby 1.8.3 will work, as long as you use Rails 0.14.0 or higher. * Rails 0.13.1 or Rails 0.14.x. * A database. Typo supports MySQL, PostgreSQL, and SQLite. * Ruby drivers for your database. * For best performance, you should have a web server running either Apache or Lighttpd along with FastCGI, although these aren't strictly required--you can use Ruby's built-in web server for low-volume testing. on a side note, i'm clueless about this ruby on rails stuff. i've gone thru perl with movable type and php with wordpress, so i want to see what all the hoopla of ruby on rails is about with typo. Quote Link to comment Share on other sites More sharing options...
stevevan Posted May 8, 2006 Share Posted May 8, 2006 You might want to check out their web site here. Quote Link to comment Share on other sites More sharing options...
Samrc Posted May 8, 2006 Share Posted May 8, 2006 Ruby has not been installed yet to my knowledge but will be coming. Quote Link to comment Share on other sites More sharing options...
abinidi Posted May 8, 2006 Share Posted May 8, 2006 assuming ruby on rails is installed, would typo be able to run here at tch? here are the requirements:on a side note, i'm clueless about this ruby on rails stuff. i've gone thru perl with movable type and php with wordpress, so i want to see what all the hoopla of ruby on rails is about with typo. Looks to me like TCH fits these requirements (obviously depending on the versions of Rails and Ruby they install...) Quote Link to comment Share on other sites More sharing options...
