acsteve Posted December 31, 2006 Share Posted December 31, 2006 (edited) I thought i would try another approach and program. I am trying to connect to my database i created in my c-panel but with no luck. It seems easy enough but it will not connect. maybe someone could help. Attached is a pic of the connect window for the program sqlyog. I have tried all that I know. I have put ftp.domainname like one does with dreamweaver which works in dreamweaver BTW. I have tried an IP address that is in my c-panel as a "shared address" I have tried http://www mydomainname, every way i can think of. Can we even connect this way.Any help would be appreciated. Thanks Steve PS attachment does not seem to work but hopefully some one has worked with this very popular program and can help. Edited December 31, 2006 by acsteve Quote Link to comment Share on other sites More sharing options...
TCH-Andy Posted December 31, 2006 Share Posted December 31, 2006 Have you gone into your cpanel (mysql section) and set it to allow remote access (a % will allow remote access from all IP addresses) Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted December 31, 2006 Share Posted December 31, 2006 Which was the same question I asked in your other thread. Quote Link to comment Share on other sites More sharing options...
acsteve Posted December 31, 2006 Author Share Posted December 31, 2006 Yes and yes Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted December 31, 2006 Share Posted December 31, 2006 Well, I just downloaded and installed this program and it works. When I created my connection I entered the following: MySQL Host address: mydomain.ext Username: mycpanelname_database-user Password: mypassword I left the port information unchanged Database: mycpanelname_database-name And I added my IP to the Access Hosts in cPanel. Doing this all and it worked. Quote Link to comment Share on other sites More sharing options...
acsteve Posted December 31, 2006 Author Share Posted December 31, 2006 Well thank you Bruce. I got it. I however was not able to connect the way you were. I had to put the ip address in my c pannel or server390.snhdns.com either way it worked. I tried your way under host name, my domain.ext but could get no where. In any case I have it now. Steve Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted December 31, 2006 Share Posted December 31, 2006 Glad you got it sorted out. I removed the duplicate post. Quote Link to comment Share on other sites More sharing options...
