RickB Posted January 15, 2012 Share Posted January 15, 2012 Hi, I used to use MS FrontPage a long time ago. I would like to create/freshen up my website and would like suggestions on what easy to use webiste creation packages I should use. I liked the simplicity of using FrontPage but would like something to make my website look more modern without having to get into coding. Any suggestions? Thanks, Rick Quote Link to comment Share on other sites More sharing options...
TCH-Alex Posted January 16, 2012 Share Posted January 16, 2012 If you are looking for open source applications you can try NVU Otherwise please check out Macromedia products such as Dreamweaver etc. Quote Link to comment Share on other sites More sharing options...
TCH-Bruce Posted January 16, 2012 Share Posted January 16, 2012 You could also look at Wordpress. Depends on what you want your website to be. Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted January 16, 2012 Share Posted January 16, 2012 Or Joomla. As Bruce says, it depends on your needs. Quote Link to comment Share on other sites More sharing options...
SteveW Posted January 19, 2012 Share Posted January 19, 2012 In addition to the other suggestions, Microsoft's successor to FrontPage is called Expression Web. There was a time when you could upgrade from FP to EW for only about $80. Quote Link to comment Share on other sites More sharing options...
RickB Posted January 25, 2012 Author Share Posted January 25, 2012 Thanks everyone for the suggestions! Quote Link to comment Share on other sites More sharing options...
