Morganza Posted July 10, 2003 Share Posted July 10, 2003 None of my image files work all of a sudden, i see them fine but everyone else see's a 404 page, this is with image and links. I don't know whats wrong. Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 I checked the server status and found this: exim (exim-3.36-155_cpanel_stmpcontrol_antivirus_rewrite) failed That has to be it, what does it mean? Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted July 10, 2003 Share Posted July 10, 2003 Can you post a link? Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 The costume designs are not showing up on a messege board, i don't know about the other pics, thanks Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted July 10, 2003 Share Posted July 10, 2003 Ok the images are showing up fine.When you say on a message board, do you mean yours or another. If another, do you have hotlink enabled? Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 I believe it's disabled, i'll switch it and see if it works. Quote Link to comment Share on other sites More sharing options...
TCH-Sales Posted July 10, 2003 Share Posted July 10, 2003 (edited) Could you post a link so we could all have a look to see what the problem is? (edit) Okay turtle explained why the link was taken down, im looking at the page right now. Edited July 10, 2003 by cerealkeeler Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 (edited) i enabled it, then disabled it again, i cant tell if it worked, here is the site where i posted them Edited July 10, 2003 by cerealkeeler Quote Link to comment Share on other sites More sharing options...
TCH-Sales Posted July 10, 2003 Share Posted July 10, 2003 I just edited the link out because it has adult content, if anybody needs the link PM me. Quote Link to comment Share on other sites More sharing options...
TCH-Don Posted July 10, 2003 Share Posted July 10, 2003 How sure are you that the images are there the others work fine. Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 someone just commented that he pulled up my image index and could not find the images i posted there. Quote Link to comment Share on other sites More sharing options...
Head Guru Posted July 10, 2003 Share Posted July 10, 2003 First of all your site is effected by the server move. Your a server8 client. I will let the gang here help you the rest of the way. EXIM is the mail server, it was stopped on the old server8, and I have just restarted it. Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 Is this something i can fix myself, or is it still an unknown? Quote Link to comment Share on other sites More sharing options...
TCH-Sales Posted July 10, 2003 Share Posted July 10, 2003 As HeadGuru said you are a server 8 client which means we were moving your server this morning, please check this thread for more information on that: http://www.totalchoicehosting.com/forums/i...=30entry20871 Now that could be the problem. I also heard mentioned that you have been enabling and disabling hotlink protection. I know several people have had problems with hotlink protection so take a look for the .htaccess file and I belive this is the code it puts in for hotlink protection: >RewriteEngine on RewriteCond %{HTTP_REFERER} !^$ RewriteCond %{HTTP_REFERER} !^http://(www\.)?****/.*$ [NC] RewriteRule \.(gif|jpg)$ - [F] Somebody be sure to correct me if I'm wrong! Hopefully that should clear it up if that is the problem. Now thirdly, I noticed that your names of the images are capped, which will also cause you problems. All paths, files, and everyting else should be lower-cased on your account. Please check this thread from the FAQ and How-To's sections: http://www.totalchoicehosting.com/forums/i...t=0entry19990 Now you at least have a few things to try out, and a few more explainations for what might have happened. Hope it all works out for the best! Thumbs Up Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 A friend of mine who is a moderator on my forum just told me he is missing some posts he made last night, so it's not just those files, maybe? Quote Link to comment Share on other sites More sharing options...
doc Posted July 10, 2003 Share Posted July 10, 2003 Your site is being moved to a new server in a new location. Once the site is moved, everything should be fine.....but it may be a little shaky in the interim. It will be worth the little bit of inconvenience though once you see how your site runs on the new server. You should have received an e-mail regarding the move. Hope this helps Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 i had 3 htaccess files i deleted two of them Quote Link to comment Share on other sites More sharing options...
Morganza Posted July 10, 2003 Author Share Posted July 10, 2003 As long as i know it's not damaged code or hacked, i'm relieved, thanks everyone! Quote Link to comment Share on other sites More sharing options...
TCH-Rick Posted July 10, 2003 Share Posted July 10, 2003 Please realize that you may have been making changes on your site on the old server. At this point, it would be best not to make any changes to your site until everything is complete in the move and you are seeing the site on the new server. Quote Link to comment Share on other sites More sharing options...
